Cb360t timing troubles
Jonezee
My cb360t runs fairly smooth on the left cylinder, but backfires occasionally and doesn't fire the rest of the time on the right. I'm pretty sure it's the timing, but I have been fussing with it for a while now and can't get it right. Does anyone know if that could have anything to do with gummed up or incorrectly setup carbs? Or a bigger internal problem? It has good spark on both sides, and points seem to be doing what they are supposed to. Any ideas for a newbie?
The bike was definately sitting neglected for a while before I picked it up, so I'll try rebuilding the carbs. It has been on my list for a while, but i've been puting it off...
Thanks!
So... I pulled the carbs apart and the diaphragm on the right side that wasn't firing was ripped in two spots. Now I need to track down a replacement as my rebuild kits didn't come with them. Hope this is the fix!
crazypj said:
Check carb sync.
The throttle butterflies need to be opening and closing at the same time.
If you haven't had carbs off and cleaned them your probably wasting your time with timing.
If bike was left standing for more than 3~4 weeks they will be gummed up
PJ
I'm experiencing the same thing, but not too badly. I'm thinking about trying to rig up some attachments to my carb boots to attach my morgan carbtune to. Does anyone here use a carb sync tool to sync their carbs on a CB350 or 360?
I contacted honda and they still sell the whole piston/diaphragm assembly for $110/pair. I've been toying with the idea of dropping some coin on mikunis eventually anyways, so after stewwing on that for a while I decided to see how well I could repair them and wait to purchase what I really want. I rebuilt the carbs, and skimmed over the tears with two layers of pit crews choice sealant. The sealant dries flexible in about 24 hours, so it took two days of waiting for it to cure before i could reassemble the carbs. Seems like it will hold pretty good for a bit so I can ride it until I get the mikunis or just buy the new parts. Thanks for the advice! Next step.... Ye old battery/regulator/rectifier system....
