CB360T
RichL
New to DTT.....in the middle of working on a 1976 CB360T.....just wish it was warmer in the garage! Picked it up from a neighbor for $50 but sat around for a couple of years until a couple of months ago. New battery, cleaned and rebuilt the carbs, moved all the wiring to the tail. Started it last week....other than one carb leaking through overflow tube and only firing on one cylinder, it runs and I'm happy! Carbs are back off the bike for fixing the overflow....not sure yet if it is a bad float or crack in the overflow tube - float height is correct. Also swapping out the coils for a set from an XS650.
very nice! you can't beat $50. thats a steal. I also have a 360 project thats been in the works for a couple years now. I just pick at it piece by piece because I cant go more than a couple months without needing to ride it. I did the XS coils on mine as well (from mikexs). they work very well. take a look at <a href="http://www.dotheton.com/forum/index.php?topic=44726.0">my thread</a> in this section. I ended up getting some angle aluminum to make mounts for the new coils. it worked really well and ended up providing a good mount for the condenser as well. I'm interested to see what you plan to do for air filters. I read a lot about these bikes not responding well to pod filters so I ended up just rebuilding my oe filters. Good luck with the carbs. it sounds like you know what you're doing. Enjoy!
If you folks are looking to install pods, talk to CrazyPJ about his pod mod. He modifies the circuits on the 360 carbs to prevent the midrange problems pods can cause and makes the bikes pull like a freight train. There's some details in my 360 build thread...
Also, you'll want to use a high quality pod from K&N or UNI to prevent blocking the air ports on the front of the carb.
It's funny that we're all swapping out coils - I had a bad set of coils on mine when I bought it, and then swapped in a crusty but working stock set, and then replaced those with aftermarket, one of which was intermittently bad.
I need to check that out Im glad you said that. I was a lil nervous about the pods after all I read about everything that could go wrong with them
Yea, PJ goes through the carbs and modifies how the various circuits work to prevent the normal fueling problems. There are several other happy campers like me on DTT who have had him go through their carbs.
You'll want to stick to stock filters or go to aftermarket carbs otherwise - a lot of it has to do with how the stock airboxes "smooth" the incoming air. The turbulence caused by the openness of pods "confuses" the pods (can you confuse something mechanical?) and causes weird fueling. It's also an issue on many other bikes. My '79 CB650's stock carbs don't like pods either, and those are mechanical slide carbs, not diaphragm carbs like the ones on the 360.
Thanx to all for the replies. $50 was a steal....neighbor just had it in storage with no interest in it and wanted to get rid of it since they were moving. I'm going to send pics to them once I'm done. I am going with pods (prob K&N) but had not heard of the midrange problem. I'll definitely check out PJs mods. I ordered coils and condenser from Mikesxs.....read about them on another 360T forum . should be coming in today. Also going with aftermarket plug wires (MSD) - used Accel wires on my Supersport but not real satisfied; read good stuff about MSD wires.
Here's a close up of the old coils....some breakdown of the case on one of them.
All the pieces and parts for the new ones...including aluminum brackets. Thanx to thrillseeker for that idea!
And finally mounted on the bike. I also bought an XS650 condenser to go with the coils from MikesXS....had to mount on the left side to run the wires easier.
And the right side coil. These coils also had uncovered terminals on the bottom. I stretched out a couple of pieces of 1/4 in shrink tube to fit over the terminals. Looks much better. Still have to connect all the wires.
Lookin good! Great to see my ideas being used by others! I ended up putting the condenser on the left as well, for the same reason.
So I wasn't planning on a complete tear down but glad I did...cracked triple clamp could definitely ruin a good day of riding.
