CB400 Top End
posibrian
Pub Flyer!!!
Are the top ends from all 78-79 CB400A's and CB400T's the same?
I can get a bottom end cheap and was wanting to swap it out with mine since I have the CB400A Hondamatic and my top end is fine.
Thanks in advance!
Top end should fit fine. Also if you can get the carbs from a non-automatic CB400 or CM400 you'll pick up a decent amount of power. Honda fitted smaller carbs to the auto to give it enough torque at lower speeds to work well with the torque converter. You'll need the inlet rubbers to go with them too...
posibrian said:
I'm taking this was a stupid question? Lol
I can't find ANYTHING and I've searched for 2 days now
The inlet rubbers for what? I also saw they used a different camshaft? Hmmm ok well I can always buy a nice set of carbs later down the road but I need a bottom end asap so thanks for answering my question!
You may just want to buy a whole 450 from an 82-86. You get more power, oil cooler and oil line to the head to protect the cams from wear. You can likely get a whole motor for less than a bottom end. The 450 bolts right in no mods needed. Also the bottoms are a bit tougher than the older 400's. You would loose the kick start. There are 4-5 models all with the same engines you can swap in. heck there is a scrapyard here that is selling 2 450 twins for 30.00 CAD ea. I paid 150.00 for mine. Made me mad when I saw the add for the 30 motors. Search for 450 nighthawks, I think that model is the most abundant.
Cheers,
Yep, plug and play. I have an 81 CM400, piston went south, did some research and found out the 82-86 450 twins were a direct swap, ended up with an 82 hawk motor used my factory harness and just swapped it out. 2.5 hours to get the old out and new in, i even used my carbs, just had to re-jet because i also put on pods and opened up the exhaust. Hits the ton for a joke now. After I dumped the crossover and a few other of the heavier parts. Get a clymer, there is plenty of places to download it as pdf. It explains the slight differences in the models. I would avoid the Rebel 450's they have different heads and gearing.
Cheers
Maritime
Dude your a life saver, I will be on the look out for one of those for sure. Hopefully I can find one soon, best bet I have right now is a 79 cm400 for $275 but that sounds really high.
Thanks again mate!
No problem. They made a lot of them. Look for CB450, CB450SC, CB450E, CM450T, CM450E. The E models don't have the Tach Driveinthe sidecover, but I believe the gear is in the engione so a side cover swap and you can run the tach, I have 3-4 side covers, you could have one fro shipping if you end up with an E model engine. Some are 5 speeds and some are 6, I would try to get the 6 if you want to cruise highway speeds. My bike is really happy going 80 MPH with a small wind screen. I have one I swap on for longer trips. Good luck. Not sure where you are located but check out Ebay, or local junk yards. Craigslist for USA or toronto area Kijiji.ca for anywhere in Canada. I know there are 2 for sale @ 30.00 ea right now in the Halifax, Ns Canada Area.
Good luck.
Maritime
The necessary gear for the tach is in the E model so a side cover swap will work.
Cheers,
I have an 82 450t in my 81 Hawk....I don't remember it having an oil line to the head...can you post pics of that? (where its attached to the oil galleys) Id love to add it to my motor. Would that have been on a latter model possibly?
I will see if I can find a photo when I get home from work. The bike is 1.5 hours away in storage. The line runs from the bottom end to the head on the front (exhaust side) it is cast in place in the head. Here is a parts fiche from bike bandit on the 82 hawk 450T. There is a forked line that attaches and goes out over the cam to spray the oil.
