CB400f airbox replaced with pods, carbs hanging
timeconsuming
Foolish until proven intelligent.
I've noticed my carbs aren't really supported by anything other than the rubber mounts to the engine block, which has caused them to start slumping downward a little bit. I suppose the old airbox used to support them up so I was wondering if anyone had any suggestions for supporting the carbs without the airbox?
I was thinking of getting some zip ties and tying it up to the frame above?
I've seen people make up brackets to hang their carbs up - no reason why zip ties won't do the same thing.
I'd love to see where they hooked the carbs to the frame if I could, not really sure where I'd strap up the zip ties to be honest.
I was talking generically - can't say I've seen it done specifically on a 400f.
But you could put a zip tie around the pod clamps on carbs 2 and 3 and then use another zip tie (or more) to link it up to the main frame tubes. That would be pretty inconspicous and it will be better than what you've got now.
They shouldn't slump if they are seated in all the way. You shouldn't see any of the front part of the carbs and the spacer plate should just about touch the boots. If you have a hard time getting them to seat try heating the boots with a space heater or heat gun before trying to mount the carbs.
Good point, I'll take a closer look at how well they're seated. I heard it was a pretty regular thing when people remove the stock air box so I just figured it was something I would have to Macgyver my way around.
I've been running pods on my 350f for years and never had and slump. It's probably just not on all the way.
Weird. Local mechanic at Trophy brought it up to me initially and said it is pretty common.
But yeah I need to mess with it regardless.
