CB400F Exhaust
rockcitycafe
I make things.
So I got a call from a guy a few weeks ago asking for a quote for an exhaust, I told him I didn't really do them unless I had a bike to build it from, and it turns out he had a '75 400F. Since I've got a '77, I did some research and gave him a number he was happy with, and now I get to build a 4-1 stainless exhaust! I got all the material in today, and just got excited to start building. He wasn't in a rush though, so I will be taking my time and minding the details. This will be a pretty mild exhaust, as the Kerker he was replacing was a little too loud and he didn't really want the extra pep too much, but wanted something a little less tame than the stock. I'm pretty much matching the original header length plus about 2" to the collector, so it shouldn't change things too much, head pipes are a match to original diameters too.
anyone have any tips before I start the pipes?
yeah, make me one.. lol looks good so far bud.. where is the muffler's finally resting spot on the bike? maybe have the headpipes kick out a bit more from stock.. tell the guy i want his kerker..
So if that fits a CB350F (which I think it might) I WANT ONE! SOOO SEXY! How much are you making them for? I'm in Richmond, VA Where are you? I could bring the bike to you If your close enough!
Great quality work right there!
If you don't mind me asking where'd you pick up your exhaust parts? Mainly the collector cause I might need one soon for a projects. Thanks!
updates: finally gave up hope of a 60+ no rain day for the rest of the year and brought the bikes in. I needed to bring the 400f in anyway to finish this customer's exhaust, so I craned it up to a good working height and went at it today. He wanted to keep it clear of the oil filter and drain plug and all, so that affected some decisions... I've also got a soft spot in my heart for the sweeping original exhaust, so I wanted to keep that look too... enjoy
and sorry that I haven't gotten back about prices yet, I'm counting the hours and materials closely on this to get a good number for price
I'm wondering about putting the collector that close to the muffler. My Hooker 4-1's have the collector right under the motor. Do you think that'll effect sound and back pressure?
I had to make a bit of a decision about that, since the original pipes were double walled and the inner diameter was smaller than what I have, and not similar to anything available :-p, I compensated by making the header pipes longer, which pushed the collector back. I think all my designing and thinking in the long run might just be overkill anyway, because there's still a baffle and the bike isn't race tuned in any other respect, so my guess is the exhaust is just a pretty noise killer :)
That's really good fabrication. You showed a couple good ideas: 1.) raising the bike up like makes construction much easier and 2.) the hose clamps to temporarily hold everything together. Well done on that. A couple observations:
1.) The collector to megaphone should be fine.
2.) I think you should have kicked the megaphone up a bit--like 20 degrees. Though I suppose it's really up to the customer.
Why the stamped collector? A 4-1 merge collector really would have looked great there.
Were you able to get the primaries equal length?
I know what you mean about the material choice. We need to call them to get the proper spec-ed tube. Perhaps I'll do that today. After taking a few weeks off, I'm itching to fire up the torch again...
--Chris
if you look close at some of the clamps, I cut windows in them to allow tacking when they're clamped, found that trick from some guy building dune buggies... I think i used the stamped collector because either the 4-1 wasn't available in merge or he was out of stock... can't really remember, but I think it will look nice when it's done anyway
that is the smallest bike stand i have ever seen maybe it would work in my storage unit?it is so small i would love to be able to keep tools and stuff under my bike and also work on it at eye level!!!!!!!
can you send me the link to buy it crazy !!!!!!!
also the header/exhuast looks pretty good ;D ;D i am stealing that steel wool wrap idea looks like a fun way to tune the tone with diffrent volumes and grages of steel wool yea??
in the upper left of most photos you can see the hooks to what are i presume tie down straps. but man they must be serious to be working under that bike that high in the air!!
the wool is a stainless baffle mat that they sell for mufflers, it's a lot more dense than the steel wool in stores, but just as cheap, it's all nice and flat for wrapping too
You are basically building THE exhaust I'm dying to get my hands on - a SS replica of a stock header - I'll take mine in the raw unpolished look with an upswept collector........
One question I have is if cornering clearance will be affected by the horizontal header pipes. The stock header definately has its limitation but its pipes run side by side angled up and tucked close to engine. Aftermarket units from yoshima and mac tuck in under the frame increasing clearance. Your exhaust appears lower slung than stock. Maybe its the angle of the photo or just the mockup stage your at.
Please don't take any of the above as negative, the work looks awesome! But as possible future customer for a set I'm watching to see if its something that will fit my needs (OK - desires).
you haven't seen the changes ;)
based on responses and advice, I was able to rework the headers and tuck the collector up underneath the points cover, it looks like spaghetti sex! I'll have pics up once I finish sanding the header pipes...
