CB400F Horn
carnivorous chicken
Over 1,000 Posts
Pulling my hair out on this one... Anyone have any ideas? Working on a 1975 CB400F. Horn doesn't work when the button is pressed. Horn does work when connected straight to battery (just to test). Current getting to black wire. Light green wire (that goes to harness and up to button) is connected properly. Attaching a wire to ground and that tab on the horn doesn't do anything either. I have taken apart the button, everything is there, cleaned the contacts, spring is fine. Any more ideas? button not grounding properly to bars -- that doesn't seem to be it.
Ill try and help, but im no expert so take this with a grain of salt.
First id say to grab a test and test between the ground, and the positive wire from the switch. When you press the switch it should light up. If not then your either not having power to the wire, or your not grounded.
Did you powdercoat the bike? Bars could be not grounding to bike. Put a wire straight to the bars and frame and check.
I think it a grounding problem. Detach your horn from the bike (leave wires on there) and test again. Black wire to the horn is always hot when bike running, the green wire from the horn goes into the loom and grounds to bars at horn switch. You could try and ground the green wire coming out of the loom at the switch with a screwdriver to the bars or frame and see if that works.
good luck, these problems often have a really stupid reason, so keep on diggin'!
Thanks for the replies guys. Got it today: horn is non-functioning and needs replaced. I tested it a while ago so somehow it took a dump between then and now. Plugged the horn connections into a light and lo and behold it works, then plugged the horn into direct connections to the battery and nothing. Total "doh!" moment. Off to the junkyard on Tuesday and then the bike will finally be done!
