CB450 71 swingarm bushing... How to remove???
joevirus563
Coast to Coast
How the hell can you remove those!!! - keep hammering with a screwdriver and there not coming out.... Any idea????
need something stronger than a screwdriver. get a steel rod.
heat the outside of the swingarm and then give em a hell of a good wack.
if they still dont come out, you can cut a slot or two in em using a hacksaw blade; just be careful not to cut into the swingarm TOO deeply.
Heat is definitely your friend. I used a correct size socket on a long extension. The socket was the right size to sit on the lip of the bushing and it popped right out with 2 whacks.
Ok but you hit the bushing from outside from inside? How can you make the bushing pop out with a socket if you can pass it trough the other bushing to hit it from inside to outside??
the socket should be slightly smaller than the inside diameter of the bushing. than rest one side on the bushing; not all of the socket will contact, but a good amount will.
you whack them from the inside out. dont be a girl; hit that shit with the thought that doing so will get you laid.
I'm not a girl... :D so I'm gonna DESTROY IT!!!!
I'll post some pick later :D HAHA
haha...
whenever i say something along the lines of girls are weak i wait for Go! to post something proving me wrong. :D
