If you already have pods, and the bike is running fine, you could put K&N's on without a re-jet. It is the pod filter style, not the brand, that requires a re-jet. That being said, K&N would be one of the better if not the best brand to go with, I run K&N in all my cars, but my bike is low budget so I got Emgos for it, basically K&N rip offs. I assume you bought the bike with pods on it already so likely the PO re-jetted. Otherwise you might be running lean and it could be bad. Put the pods on and run a steady cruising speed for 10 mins or so. Then in a good spot pull the clutch and kill the motor. Pull over and pull the plugs. If they are a nice brown you don't need to re-jet. If they are grey or white or there is white flakes on them, you are running lean and could detonate a piston. You should re-jet up a larger size. if they are oily, sooty(Black) or smell like fuel, you need to go down a jet size as you are running rich. There is good reading on the net, Google carb tuning and it will explain a lot. Basically the jets in your carb put fuel in with the air as it enters the engine. If they are too big, you get too much fuel and run rich, worst thing is fouled plugs, if they are too small you get too much air and run lean, this can lead to BOOM. anyway, pods increase air flow and so you need to make sure you increase fuel enough to keep the motor happy. Hope I didn't confuse you and I am not an expert, just an enthusiast, and learn by doing. I put pods on my 81 450 and a straight exhaust, I had to rejet to get the engine to run properly after. Went up from a 108 to a 128 main jet and from a stock 70 to 72 slow jet. They are usually a little brass screw with a hole in it. The number is the size of the hole.
Cheers
