CB450 Build "Well It's About Time"
Definitely can get you the list but there are a few items that had the wrong thread size so I have a lot of unused hardware. I'd say ~10-20% were extras and therefore a waste of money. The ones that were useless were the larger sizes like M8's M10's and M12's (nuts and bolts) but if you delete those from the list you've got the vast majority of what you need. Not to say that I haven't ran to the hardware store for an extra bag of M6's from time to time ::)
4 pieces #6416 - Metric socket cap
1.0mm x 10mm
3 pieces #6419 - Metric socket cap
1.0mm x 20mm
16 pieces #6420 - Metric socket cap
1.0mm x 25mm
31 pieces #6421 - Metric socket cap
1.0mm x 30mm
4 pieces #6423 - Metric socket cap
1.0mm x 40mm
1 piece #6424 - Metric socket cap
1.0mm x 45mm
5 pieces #6428 - Metric socket cap
1.0mm x 65mm
4 pieces #6430 - Metric socket cap
1.0mm x 80mm
2 pieces #6459 - Metric socket cap
1.0mm x 90mm
1 piece #6441 - Metric socket cap
1.25mm x 55mm
2 pieces #6435 - Metric socket cap
1.25mm x 25mm
5 pieces #6437 - Metric socket cap
1.25mm x 35mm
2 pieces #6438 - Metric socket cap
1.25mm x 40mm
1 piece #6440 - Metric socket cap
1.25mm x 50mm
2 pieces #6442 - Metric socket cap
1.25mm x 60mm
1 piece #6443 - Metric socket cap
1.25mm x 65mm
3 pieces #6444 - Metric socket cap
1.25mm x 70mm
2 pieces #6447 - Metric socket cap
1.25mm x 90mm
4 pieces #6451 - Metric socket cap
1.25mm x 130mm
4 pieces #6467 - Metric socket cap
1.5mm x 35mm
2 pieces #6468 - Metric socket cap
1.5mm x 40mm
4 pieces #6477 - Metric socket cap
1.5mm x 90mm
5 pieces #6689 - Metric socket flat head
x 1.0mm x 25mm
4 pieces #6677 - Metric socket flat head
x 0.8mm x 25mm
3 pieces #6675 - Metric socket flat head
x 0.8mm x 16mm
3 pieces #6693 - Metric socket flat head
x 1.0mm x 45mm
3 pieces #6688 - Metric socket flat head
x 1.0mm x 20mm
1 piece #6377 - Metric socket cap
0.5mm x 5mm
6 pieces #6407 - Metric socket cap
0.8mm x 10mm
1 piece #14652 - Cotter pins
13 pieces #4813 - Metric lock washers
4 pieces #4811 - Metric lock washers
12 pieces #4812 - Metric lock washers
1 piece #4810 - Metric lock washers
3 pieces #4817 - Metric lock washers
5 pieces #4513 - Metric flat washers
5 pieces #4514 - Metric flat washers
10 pieces #4515 - Metric flat washers
75 pieces #4516 - Metric flat washers
35 pieces #4518 - Metric flat washers
15 pieces #4519 - Metric flat washers
5 pieces #4520 - Metric flat washers
8 pieces #10322 - Metric cap nuts
10mm x 1.5mm
5 pieces #4773 - Metric hex nuts
0.5mm
5 pieces #4775 - Metric hex nuts
0.8mm
20 pieces #4776 - Metric hex nuts
1.0mm
35 pieces #4778 - Metric hex nuts
1.25mm
15 pieces #4779 - Metric hex nuts
1.5mm
5 pieces #4780 - Metric hex nuts
1.75mm
3 pieces #4781 - Metric hex nuts
2.0mm
So the rear fender, its held in place by the original rubber to keep it rattling, its chopped in half and held under the seat pan by a long bolt and rubber washer combo which I decided today is also going to hold my RR combo :) For an added measure I drilled a few holes and safety wired the whole thing on the cross member near the original rubber holders. Hope you can see details in the pic below. If not I'll try and get you better ones.
Finally got a drill press in my little shop, its been one of those tools that I never thought I'd use as much as I do and its only been a day! Fixed up the gauge after letting go of the fact it was going to be next to useless in the headlight so low down.
Thanks for sharing that Finnigan.
