Cb450 build
TheYoungBuck
Learning the trades as i go
Im the proud owner of this 1972 cb450 and it was all original when i found it, making me the third owner. The owners manual had all previous dates and recordings of servicings throughout the bike. I've been dieing to make a thread but haven't gotten around to it, so her she is! Already started the tear down now and moved everything into my buddys shop. I'll start posting a picture of mock ups and final fabrication.
Already starting the tear down along with my buddy sean and his 74 cb450, man keeping our parts seperate might be tough ::) :P
Finally everything taken apart and seperated in the new shop, starting to mock things up
Started to make the skeleton of my seat and got it finished at the end of the day, get back to it soon and finish it with some 20ga sheet metal, I used 1/4 hot rolled round stock as the frame work.
Or, as long as trail numbers are not adversely affected, install longer rear shocks to regain hoop tire space. Chain and swingarm clearance may also be negatively affected by attempting this cheat.
I started to take that into affect when looking at the height between the rear wheel and hoop, thinking 14.5 for rear shocks to call it safe ? What do you guys think?
the longer shocks will make the bike handle more nervous and twitchy, why not just do the job right and make it have clearance ?
I weigh 140lb maybe 150lb wet guys... How do you compensate for the clearance needed then? Longer and stiffer shocks would be the answer? Correct me if im wrong, help me out here guys...
Then use a skateboard for a seat pan... haha, really if you never ride two up @140 you may never bottom the thing unless you single the railroad bump... pull the shocks loose and let er drop, mark the spot under the seat where the tire hits and put a nice little patch of sheet metal to skid on. But seriously if you want to dial in the suspension for a 140 rider you need to send the fork legs and shock off or get with a suspension guru here and order up the parts to dial it in, changing the springs and replacing the seals up front will be your biggest battle first go-round... I don't do it, it's like paint and roofing... a set of tools I don't want..
go ahead and make the hoop stick out longer to the rear or kick it up,you got the tools and skills ;)
you will need LIGHTER springed shocks not stiffer esp if you are riding solo.you will be wanting to get some good shocks the stock shocks are crap.to check clearanmce, take off one shock, set the other on soft and ratchet strap the remaining shock all the way down hard to bottom.only pull down with the strap on the shock side you dont want to twist the swingarm
then leave AT LEAST an inch vertical clearance to your FENDER and or seat pan/rear hoop
you really should get some good shocks now and do it all at once good shocks will likely have more travel
having the tail so low looks silly anyway kinda like a dog dragging ass on the carpet
Inspite of the nice work welding in the hoop and establishing the wire frame hoop, but I agree with the others, best fix is to rework the hoop to give stock OEM clearance over the rear wheel. But that clearance will eat into the useable space for hiding electronics under the hump. Remove the springs from the shocks and allow the shocks to bottom out and then create a hidden splash shield/bottom for the hump area. That way you know for sure wheel clearance is provided and how much room you will have available inside the hump to hide components.
There is a 1 1/4'' gap between the wheel and the hoop where the wheel is, im thinking about going with 13'' shocks. What do you guys think about for size? I know if I go another inch it will kick it up one inch but what if I go 13 1/2''? Will this be to much? I really hate long rear ends on cafes so I don't think I want chop it and make it longer now.
you gotta check the clearance the way i described or take off the springs either way,just do it right, don't use gueswork or expect anybody to give you the right answer over the internet
stay close to the stock shock length within 3/4"
