CatDad
I am getting a lot of vertical play in my cam shaft as I was adjusting the cam follower clearance. In the video below you can see the right side of the exhaust cam shaft. There is a mil or so of movement as I am rotating the eccentric for the left exhaust cam follower. I checked the clearance between the cam and the bearing to be within spec (.076mm on R, .127mm on L = .203. Spec from my manual is .05-.35). I just finished rebuilding the engine but didn't check the diameters of the cam or bearings. The bike is a CB450 K6 with about 10k miles.
So my question is, is this movement normal? If not, what are my options for remedying it?
Thanks for your help
https://www.youtube.com/watch?v=t1CTECcFwj4
