TripleKing
I have an interesting situation with my son's 1970 CB450. The bike has Mikuni VM32 Carbs. They were pre-jetted for the 450 by Dime City and I richened them a bit to account for the Uni-filters and unbaffled exhaust (exhaust came that way when we bought it.)
When you jump on the throttle, the right cylinder will pop and sometimes give a backfire out the right exhaust. However, it you roll on the throttle all is well. The left side does not do this. Both carbs are set up identically. The only difference between cylinders I can see is that the left (which does not pop) has compression of about 168 PSI and the right (which does pop) has compression of about 162 PSI.
Plugs are fine and there is no sign of the right cylinder running lean (spark plugs, no pipe discoloration and no popping on decelerartion). I would appreciate any input.
