cb450 clutch: non-engaging
ozarkansas
It feels to me like its working whenever i pull the clutch in but my rear tire is still not breaking loose. I can turn it with some effort. Like i said it feels like everything is alright on the lever end. I've tightened the piss outta it until it started popping and going loose, but when i release it, it gets tight again.
oh and also i popped out my inlets to my carbs because of overly tight lines. Can i just pop them back in without a worry or is there more like putting an adheasive on it?
Not engaging or not disengaging? Sounds like it went over center and needs to be re-set and adjusted properly.
Whatever won't let me use my clutch. I didn't see the ball bearing in there but then again my other 450 does'nt have one either and it works fine.
The question I was asking is if you pull the clutch lever does the clutch lift and separate or are you saying that you let teh lever out and the clutch slips? This isn't semantics, it's describing the symptoms clearly.
Assuming that your earlier comment about you "tightening the piss out of it", it probably means that when you pull the lever the clutch does not disengage. Have you examined the side cover to see if the snail cam is in the right place and did you follow the procedure set out in the manual?
http://www.cb450stuff.com/manual/ClutchAjd.htm
Its whenever i pull the lever in. That is the problem though. It feels like the clutch is working, but its not taking it out of gear. I tightened it by means of the adjuster on the side of the case, not the lever (which is tighten as far as it'l go.) I got a new barnett plates. We'll see.
Did you follow the process in that link? It really sounds like the adjuster in the side cover may have turned and is in the wrong position. Slacken the cable and then adjust that large screw on the side so there is just a small amount of play, and then take up teh slack.
