CB450 external oil line? Or Stock? If External what size?
joevirus563
Coast to Coast
I'm thinking of putting some external oil line to my cb450 to feed the cams.
Now, should i do it or keep it stock?
If I do it, what size of line should I buy? Any idea of the lenght? With only crush washer to seal them?
Do I need to cover the original oil passage in the head and cylinder or just leave it as is?
I know some kit are already selling with oil cooler. I'm looking just for the line solution.
http://www.cappellinimoto.it/index.php?option=com_djcatalog2&view=itemstable&cid=2&Itemid=7&lang=en
Google works for me.. cappellini is $$$$ though but that should give you an idea
I hate to tell you that but, you're not answering my question.
I've already made the search on google.
I'm looking to make my own oil line not to buy one from another person.
I want just the line not with the cooler.
I want to know the size of the recommended line and the lenght if possible.
And I want to know if I have to solder the original oil passage in the head and in the cylinder.
Joe, why do you think you need external oil lines - because you have seen them on other bikes or because you have had a melt down? Not many people - even racers use external oil feeds. Stock should be OK as long as the feeds are all clean.
I'm not a big fan of external oil feeds and would rather convert the camshafts and cam towers to needle rollers.
Did you get a new liner yet?
Hi!
Yep got new liners and they are bored already.
Problem is that I'm scared of eating the cams and followers because of the modification I've made to the torsion bar...
The oil pump is known to be weak right?
Thats the kind of answer I'm looking for!
I'm thinking, 10$ mod VS new cams and folower... while I'm there I could do the mod or just leave it that way.
My intentions were to show you a place that has them so that you might be able to figure out what sizes other companies are making, possibly send them an email asking questions. I have no idea what size lines you need but I do know that you have to maintain balance in the system or else you will end up with flow problems which can lead to oil starvation in other areas.
As far as plugging holes, yes I would believe you would have to plug the holes either in the head or in the top of the top crank case right at the base of the cylinders.
If I do the mod can I plug it in the right crankcase cover where the pump is pumping oil?
No that oil gallery headed up from the right side also feeds the crank and the transmission.
Thanks!
Ok I'll think about it.
I'm usualy running 5W40 oil synt so I don't really know if I need that mod but for sure I'm thinking about it... would it help the engine if doing a lot of 50mhp interstate run?
At 50 mph, it's just ticking over ;-) That torsion bar mod is rarely needed or desirable on the street. The idea is to add more preload to avoid high RPM valve float, but if it's rarely exceeding say 9 grand, all it does is add more load.
Make sure all the oilways are clear. I can't remember what the pump looks like on those. If it's a piston/plunger type, you could possibly get a larger one machined and take that opportunity to tighten up clearances slightly.
joevirus563 said:
Hi!
why not just put the thing back to stock and melt metal no more ?
are you smarter than the engineers that designed that system ?
even IF you can make the stock cam lobes and rocker faces have anything but a shortened life how long do you think the torsion bars will last ? they will be running much hotter as well and when fatigue sets in and one of them snaps it is going to be really sad :'(
YES THE TORSION MOD
i think it is a bad deal all the way around , totally uneeded and only gonna create problems
no but i have taken apart 3 or 4 450 engines and more than half of them have significant wear on the cams and followers,putting extreme extra loads in there just seems crazy
i think with clear oil galleys,good condition pump and good parts and good maintanence it should be fine,stock
but if i was going thru all the trouble building a 450 i would be sure the parts are like new or otherwise re-surfaced
