CB450 mikuni VM32 throttle and cable???
joevirus563
Coast to Coast
Hi, which cable and throttle I should use with my mikuni vm32?
I don't have the stock one neither the cable.!
THanks!
Big Rich said:
Stock should be ok.
At least my cable was a direct swap onto VM20's.
I don't have the stock one... so at the same time I was thinking about a good upgrade (Trottle assembly and cable for VM32).
THanks.
Well, I'd say Motion Pro makes the best cables possible. But unless you KNOW that stock cables + fittings will work, you run the risk of spending good $$ on nothing.
Well it looks like Motion Pro doesn't have a stock cable for a CB450. However, they do have cables for CB350's. This would be for the stock Keihin carbs anyways.
Your best bet is to find a stock throttle cable, and see if it will work. If not, call Motion Pro. They can walk you through what measurements you need. They are very helpful. Maybe their CB350 cable will work?
I am running VM32's on my CB450, but I have clipons, so the length was custom. I gave them the measurements, and they made me a custom cable. It wasn't cheap, but it is very nice.
Wasen't cheap means how much?! :)
