bobjohnson
Coast to Coast
Ok so i finally got my bike in perfect running shape and wouldnt you know it, something else happens...
I took it out last night just to make sure everythings running ok. It was running fine for about 30 minutes, and then i started getting this weird mid-throttle miss/hesitation/slight backfire. It was fine at maybe 1/4 throttle, and 3/4-full throttle, but at 1/2 throttle (cruising), it was running like crap. I noticed at the same time my lights were getting a bit weak, the blinkers would blink a few times and then go solid. I didnt think too much of it as im used to my 125 twin, which runs 6v electrical, and using all your lights at once is a luxury, not something to be expected ;D
So originally i was thinking it was running lean or rich, but i pulled the plugs this morning and they looked perfect. So i rode it to work and the weird hesitation was still there, but it got better just as i was getting to work. Then on the ride home, it was crap again. Then I lost my gauge lights and the headlight was really really dim. So this is when i started to suspect the battery. I limped it home (or, well, revved the hell out of it to bring the charge on the battery up), and put the multimeter to it. The battery was sitting at 11v.
Could that be the cause of this issue? I know the 450 runs primarily off the battery, but i would think 11v would be enough to make a good spark. Maybe im wrong? Its also got a 9ah battery instead of the recommended 12ah, but its been fine up until i started riding it at night time. Would that really make a difference in how well it accepts/holds a charge under load (using the lights etc)? I know some guys on here are running 6ah batteries and even 3ah batteries, but thats on different bikes as well...
