Im guessing its the same as the one on the 350, my manual says its 16mm. I thought I needed to remove this when splitting my cases and I tried using needle nose pliers in two opposing slots. This did not work, and then I gave up since I found out that I can split the cases without removing it. Id probably just buy the tool if I were you, Im probably going to do the same to make cleaning the thing easier.
