brian weir
the new bore size is 2.895" done by a shop that has done a number of 450's with these pistons, referred to as 12th overbore on the net, I calculate about 492 cc.
the rings fit nearly perfectly with probably .0005" gap, just enough to get them in. I will use the listed Honda gap but wonder
1/ best way to take material off -dremel tool very lighltly I think? or maybe file.
2/ lean towards the larger end of the Honda gap tolerance more than the smaller or go in the middle?
3/ I realize it will wear and you can't glue the ground stuff back on...
replies appreciated,
brian
brian
