CB450 performance modifications
I recently picked up a lovely bike, lot of work put into it and it's great. The motor is bone stock though, I was wondering a couple things. It will be a street bike only.
1.Would mikuni carbs and velocity stacks (with screens) give me a significant upgrade in performance?
2.Should I look into porting my heads, a mild cam, or just leave them alone since the motor only has about 8,000 on it.
3.Anything else would be helpful!
Mikunis would help, most CB450 racers thow them on. Don't worry about porting though you wouldn't get much bang for your buck on that one (especially without having access to a flow bench). Just cleaning out the molding lines and giving the ports a slight honing would give you better results. You can send the cams out for grinding but if you're gonna do that you might as well do a valve job and do the coil valve spring conversion. With proper jetting, mikuni carbs, velocity stacks and opening up your exhaust a bit is probably all you need to do. Just make sure the jetting is correct. I have a big bore kit (74mm pistons), pod filters, with open exhaust and I didn't jet right. Needless to say I hot seized and froze my #1 piston rings in a heart beat.
I've heard changing the front and rear sprocket sizes helps. Off hand I can't remember the recommended # of teeth, or even what they are stock.
GWC: are you happy with the big bore pistons? Did you get one of the copper head gaskets? If so where. I am considering doing this if my cylinders need to be bored, might as well go big!
We'll see about those pistons. There was a quality control issue with one of them (slightly larger than the other). I got the pistons from ruty riders on ebay and the copper gasket I got from England. I'll try and find the link to the site for you.
Would I do it over again? Probably not. If I had to rebuild and it required boring to the next size, I couldn't due to not having any more material on the sleeves to bore out. I might change my mind after I get the engine back together and jetted right. She might blow the doors off a stock 450. If you're not in a hurry you might want to wait a while and I can keep you updated on how it does.
Here's the link:
http://www.d-mengineering.co.uk/store52/agora.cgi?product=CB450/500T&xm=on
I also got the starter eliminator blank plug from him too.
$65 just for the head gasket? I realize that isn't that expensive for what your getting, but I'm on a budget and I'm not building a hot rod. I was considering doing it because those pistons from RR are actually cheaper then the OS pistons I've seen elsewhere. I guess you get what you pay for. Combine the cost of the pistons and the gasket, I guess they would probably still come out to be about the same as standard pistons and gasket.
I don't plan on putting tons of miles on my bike, so I figured that if the 12th over cylinders got out of spec, I could just buy another set. I've seen at least one set of jugs go up on ebay just about every week now.
I will be taking my jugs to the machine shop in a couple weeks (when I get back from a business trip) to get measured. I'm pretty sure they will need to be bored out, so I will start looking for pistons then. Do you still have that set for sale? Probably cheaper to get them from RR since you would have to ship to the US.
Here's some good 450 tips and a couple of performance mods: http://www.sohc4.net/index.php?q=node/274
CC
Nice tip on the springs. Hadn't heard that before. Not going to try it though. ;)
Gage Werke Composites said:
I did the spring trick on mine. Sure helped on the revs. Don't have to worry about valve float as much either.
Where do you grind the tooth off? The end of the inner bar or on the outer bar under the cam follower?
Is it hard to get the springs back in? I haven't tried yet. I made the spring tool out of a cheap socket already because I thought I needed it to get them off.
You have to grind the tooth of and the end of the inner bar right next to the one that is already ground off. Just make sure you grind the one that will make the torsion bar tighter not looser. It's easy to get them out and back in, just make sure you keep track of where you pulled the bar out of. They need to go back on the same valve for them to work right.
The cheap socket tool works great (that's what I used). Just make sure you remove the torsion bar dowels, put the assemblies back together, use the socket and a torque wrench to torque them enough to put the dowels back in and then throw the bolt back in. It's easier than it sounds.
