Cb450 running on one cyl.
Gerdlager
I just got a 71 cb450k4. Its my second day of working on the bike and I got it to start up. Very happy, until I saw gas and air coming out of the non-firing cylinder. Im guessing that the non-firing cylinder has an intake valve that is out of adjustment. Any thoughts would be greatly apreciated.
From the intake side?
Set up the valve clearances properly first anyway, its pretty important on the 450s. Then make sure that cylinder is getting spark. Maybe the slide is getting stuck? Theyre a pain on the 450s, they gum up really easily.
Gerdlager said:
It is coming out of the carb. Forgot to mention that.
That kinda scared me - I thought the valve adjustment covers or exhaust pipe was off. Was gonna say that is probably the culprit.
+1 to Bob with the valves. Any other symptoms / previous work you've done on the motor?
today I adjusted the non-firing cyl exhaust valve by eye looking in the spark plug hole. adjusted the timing and now I am firing on two cyclinders. I did crank the engine over by hand to make sure I did not overadjust. tom I will pull the valve covers and adjust properly.
uhhh theres no way you can adjust the valves on a 450 by eye, let alone by looking through the spark hole... Please please please download the manual and follow the proper procedures before you run the engine again (take note of the index marks and which way they should be pointing). Otherwise you are just going to end up burning up those valves.
I just got the correct procedure to adjust the valves. But i cannot get the generator cover off because previous owner has stripped the bolt heads.
Is there another way to get to tdc safely?
No need to get to TDC to do the valves (i know the manual says you have to). Just make sure the cam lobe is pointing away from whatever tappet youre adjusting. Turn it over slowly by hand with the kickstart.
Also, you can slot the screws with a dremel to get the stator cover off. Or if the screws have a bit of a head left on them, use an impact driver with a flat philips head bit. Should come off.
got the valve adjustment done. Changed the oil and the bike is running alot smoother. New problem is when the throttle is pulled the bike stays at 3k rpm. Sprayed tbe intake area with starter fluid and no intake leaks were found. Followed the carb adjustment procedure and the problem is still there.
Possibly a sticking throttle cable? the butterfly appears to shut when the throttle is disengaged.
Welcome to my nightmare. I have the exact same issue... 4 weeks and counting. Ive checked everything, the last thing i found was i didnt have the valve breather hose on. Havent had a chance to get a new one yet, but someone told me it wont fix it anyway. Im heading up to the shop today to get a new rear tire so i'll ask him his opinion. If he has anything worthwhile to say, ill let you know...
OK thanks for the help.
Reset the timing yesterday. rebuilt the carbs for the second time and put some liquid wrench in the throttle cable.the bike is now driving fine with no issues except for the sticking throttle. Maybe still some junk in the cabels.
If you check my thread, i had a chance to ask the guy at the shop. Basically he said theres nothing i can do, its a flaw with the 450 carbs. He could be wrong but honestly with everything ive tried i think he might be right.
My issue was a bit different though, my idle would hang at around 2k rpm and slooowwwly creep back down. It also wasnt every time i cracked the throttle, its very intermittent.
If you have a true hung idle (it never drops back down), id say your carbs probably arent completely in sync yet.
