CB500/550 dual disc parts
scott s
Over 1,000 Posts
DTT BOTM WINNER
Longer bolts, speedo drive (which will also work on a CB750), double banjo bolt and drilled disc with the correct pattern for the RH side. You could also use the disc on the LH side, but if your LH side is already drilled, this is the matching disc.
All you need is another hose, caliper and a couple of crush washers for the banjo bolt.
$150, plus shipping.
