CB500 charging problem
Yamaki
So my friend has this CB500 which is having some problems with the charging system.
It has a Lithium-Iron-Phosphate Battery (Revamp)and a custom wiring harness.
I get 13-16 V when i measure on frame/ solenoid when the engine is running, 13V when its not.
Tried two different Voltage regulators, same results.
Rectifier is new.
But after a while the lights dim and the bike shuts off.
Tried with two different batteries (same Life type), same result.
What im a missing here?
I can take some pics when i get home tonight, maybe that'll shed some light on this problem.
He has been building on this bike for a year now, and he is devastated that it doesnt run like it should. please help me help him 8)
Is the battery going dead at that point?
My usual advice for anything like this is connections. Check battery to ground (clean ground wire to frame connection), check the positive (remove, clean, replace), Check ignition switch and wiring connections.
Make sure the regulator connections are good. If the ground on it is weak, it will not have a good voltage reference.
99 out of 100 times, it a connection problem.
Voltages over 14.4 will cook Lithium Ion batteries (usually takes around a month though), even the Iron Phosphate type.
Higher voltages will ruin them sooner, so 16V may be enough to reach that point.
Try a sealed or AGM battery and see if you get the same result.
Yea, when the bike has been running for a while, it fades off and eventually theres not enough juice for the coils/plugs and it dies.
I'll try to look at the connections tomorrow, i hope its just something like that. We even tried running the bike with a condensor, but of course that didnt work either. ::)
I just read about that earlier, this was news to me. Live and learn :)
I will try with a regular lead battery tomorrow after i have tested connections/switches/ground.
If the current is not going to the battery, it will read high. I suspect a bad or weak connection, so the charging system is making volts, but not actually charging the battery. A weak ground can do this. The regulator uses the battery and ground for a voltage reference.
If the battery isn't actually connected to the output of the alternator, the unloaded voltage of the alternaotr will be high, as no current is going to the battery. the battery runs down from the ignition.
High resistance connections can give some some strange readings.
So battery + to - gives one reading, Battery + to Chassis gives a different reading, Alternator + to Ground gives another.
It's the same theory of battery eliminators. How can you run without a battery? Same way you can run without the alternator connected. I suspect the alternator is just not charging the battery, probably to a bad connector between the battery and the rectifier, or regulator.
Just a guess, as I don't really know exactly what he measured where.
If he listed for instance, battery +/- volts, Solenoid +/- (bat) volts, Solenoid + to chassis Volts, Battery + to chassis volts, Volts at ignition switch to chassis, etc, I could guess even closer where the issue might be.
If the battery is going dead, and the bike quitting even though the alternator has 16 V., that 16 volts is not getting to the battery or the coils. so there must be a disconnect.
I will go and get the exact measurements on the following if i can make it before work today.
Will try with both lead and Life battery, engine on and off.
Batt +/- Volt
Solenoid +/ Battery - Volt
Solenoid +/ chassis - Volt
Batt +/ frame - Volt
Ign. switch +/ frame - Volt
Heres a pic of said Honda.
My friend will be at my place later today, so hopefully we'll get it charging today.
Cool looking bike. I am having charging headaches also. My symptoms are similar to yours if I figure out the cause of my problem I will let you know.
Sent from my GT-I9300 using Tapatalk 2
i thought he was reading the voltage at the battery terminals?
He said solenoid/frame in first post.
Sent from planet Earth using mysterious electronic devices and Tapatalk
^Yup, solenoid-frame.
Anyways, we tried to run the bike with a lead battery 12V (i dont remember the Ah) but the bike ran good and did not deplete the battery.
The weird thing though; It only showed 7,something Volts at battery poles, same at solenoid-frame. But the bike ran like it should.
Voltmeter/multimeter is fine, tested on another bike.
He might make a batteryholder for a normal battery and run it like that now.
Bonus story time: The battery we used was his brother in law's, and on his way home he dropped the thing, making it crack one of the cells open. It was basicly brand new and had a pricetag of 140 dollars.
Thanks for all the help for now, we'll try to run it by a Honda guru one of these days to see what he makes of it.
Well, in that case he should have gotten the meter at the battery terminals. The way he did it does not make any sense. You do know for sure now that either the ground cable or the cable from solenoid to battery is faulty.
