CB500 Internal Fork Stops???
will46r
Does anyone make an internal fork stop kit for a CB500? Can't seem to find a kit available on the int3rb3bz. I've swapped a GS500 front end onto the bike and really don't like the ugly fork stop bumps on the triple tree. I guess I can machine one up but was going to check for availability first. Thanks
Not familiar with a kit for that but when we built my frame we did an internal fork stop by welding in a 1" long 1/4" square steel bar vertically on the inside of the front center of the neck and then 2 of the same size pieces on stem itself at the appropriate angles off center. When you turn either way the stem pieces contact the neck piece to stop the turn. Effective and totally hidden.
Thanks O1Mark.... I'd seen that, didn't know if there were other options available for the CB. I may machine one of the cup/tab and bottom cup thingy.
