cb500 slow jet problem (New kit)
supercafe
Coast to Coast
whats up,
so i bought a keyster carb kit from e-bay.
every thing fits in the carb, the only thing i see that might be a problem is that the slow jet is differant.
they are both the same #40 and the part that screws in with the holes in the tube, are the same height and diameter. on the part that sit in the bowl, the new one is smaller in diameter and shorter, about 1/8 to 1/4 shorter. the part says cb500 and every thing else looks good. i set up the bowls to spec 22mm.
will this be ok, will it work ok??????????????
i need to know, ready to install them.
any way, thanks,
later.
Did you ever get this resolved? If it's just the slow jet, I wouldn't even worry about it too much. Probably re-use the old one and be fine.
ya,
i am going to try the new ones and if ok great if not, reuse the old ones.
was just seeing if any one has ran into this before, or knows if honda made a update during the years.
any way, thanks
later.
