jakeoff51
hi guys got a question for you. from my understanding when you open up the exhaust and intakes on these bikes it usually leans them out? in my case i have done out with the retarded expensive air cut out valves by making a nice little gasket to block them off, and before hand it was runing a little lean. a little of that was due to leaking intake gaskets. which i took care of that with the air cut outs. as soon as i was done and ready to run i could barely get it to run. so i synced the carbs up manually and got it to fire up, then did it with gauges. well after that i took it for a hard ride and cut her out at wot. yanked the plugs and they were dark brown close to black. which means its running really rich if im correct. did the same thing at different throttle positions and even idling. idle was the only time it was running nice tanish grey.
i also have old gm style car coils on it due to the factory ones being weak and the gap to around 45 like i would on a chevy v8 would these coils cause it to burn the fuel more efficiently causing my free flowing set up to burn rich?
any help or input will be taken and appreciated thanks guys
