I've revived two CB500Ts so far doing what needs to be done and then usually kick starting. This bike has a none functioning electric starter so I can only kick start it at the moment, its runs on one cylinder very rich due to some nonce putting pods on it with no jetting and a burnt coil due to again that someone charging the battery with the key on. So I swapped the good coil around to try the other cylinder and reconnected it to the contact breakers.
Anyway its the first time I've ever experienced kickback with this model bike and it was happening regularly, my knee is a little sore after maybe 8 kick backs but worst of all it puts the fear of god into to me as I've heard of people with broken legs? I got the bike started for maybe 10 seconds, then couldn't get it back up presume the cylinder is flooded.
Question is what could this kick back be from? I've never had to deal with a problem with a kick starter before.
I've thought of a few possibilities:
1) The contact breaker connection I plugged the coil into is out of time, I will try swapping the connection tomorrow.
2) Something to do with very rich mixture on the bike.
3) There is something failing in the kick starter mechanism.
4) Something else!
Any ideas would be appreciated.
P.S. Forgot to mention that although the kickstarter works, it looks ever so slightly bent downwards by the previous owner, not sure if this indicates heavy/bad usage..
4) Something else!
