CB500T timing problem.
jonathan
My 1976 CB500T is acting up. When I go to time the points, the left cylinder is dead on at ideal and when it advances. However the right cyleder (using a timing light) jumps around sporadically to the left or right of the mark. Any idea on what would cause this. Thanks in advance.
I've read about this before, and I think it was due to the advancer shaft either being worn or the washer on the end under the bolt not being thick enough. IT causes the cam to wobble and the timing on the right side to be wierd. The 450's had the same issue, the fix was simple if I remember, I think it just took a shim.
It's been discussed on www.hondatwins.net/forum and on http://www.sohc4.net/, I just have no idea where. Search your terms and add 450 and hondaman into it as I believe he was the one that figured it out.
First off thanks for the fast replys. So I have not had time to check the springs and could not find the post you where talking about. However I took a look at the bolt and washer you where talking about. I don't see how that would efect just the right cyleder. Also if the shaft was worn it to (i think) would result in both points acting weird. I will check the springs and get back to you all. Any responses or ideas. Thanks
So I did a whole slue of tests this weekend and came up empty. I tried a thicker washer, checked the springs, checked most of my electrical. Still can't figure it out. I think I should add that my right cylinder is missing and causing my timing to be weird. I am taking it to Mark Paris (hondaman) this coming weekend to see what he has to say about it. I will post back after I meet with him.
How old are the points?
If ign is left on and points are closed, they heat up the return spring which goes weak
here's link to points cam from HondaMan
http://hondatwins.com/forum/index.php?topic=1126.0
I have replaced my points and resently cleaned them. I have also replaced my condencer. Thanks for the link. So I tried mark's fix and it did not help. However it did need a good clean. I was going to replace the avancer springs but can't find anyone that sells them. What else would cause it to miss. Thanks
MIkes XS sells Yamaha ones and I have some Suzuki ones.
Quick and dirty, remove one spring, cut off loop, bend next coil over to form loop
leave the other spring so it only works around 2~3K
You did grease the points heel when you fitted new ones?
could just be worn down already?
If it comes to it I will cut them down but I really dont think that is the problem. Not shore what the points heel is but I greased the advancer shaft and inside of the the points cam. Any other thoughts
The points hell is the bit that rubs on points cam.You put a spot of high melting point grease in the 'angle'
If the heel is already worn, it won't make a difference greasing it now
Can you post a pic looking straight on at points plate?
Something like this
Good pic, in high res I could enlarge it a lot
Points look fine
The opening point of points cam is at 9:00 o'clock position, the right points are almost on the closing ramp
You need to set gap at maximum lift which, it the pic, is at about 12:00 o'clock position
I have set them like that. Both points are at .13" the left is spot on the LF mark and the right is spot on at the F mark. They both advance with mark being In between the advance mark. However at 4 grand the right cylinder starts to show that it is missing and anything above gets even worse. Would a bad regulator cause this? By the way thanks for all the help Crazypj.
Check carbs are not vibrating too much, remove filters and check slides are lifting at 4,500
You have checked carb slides move free and not sticking in piston housing or guide tube?
Yes I have and they check out. I went and spoke with Mark paris and he suggested rechecking my floats and check to see if a dimple has formed on the float arm from the spring. He also wanted me to check the float needle for a white film. I will check these things and get back to you. If you have any other ideas let me know. Side note I over charged my battery the other day and drove it to work and it ran a little better for about a mile.
Hmmmmmmm....................................................................
Could be multiple problems?
You know how to check rectifier and charging system?
Yep I have checked the charging system. I think the regulator is bad. The rectifier is 0 Ohm's in one direction and 12, 5, 5 Ohm's in the other. According to the climbers manual it is suppose to be high in one direction and low in the other, so I think it checks out. I agree, it probable is a combination of problems.
So I cleaned both carb's thoroughly and check for the dimples on the flout arms. There were dimples but they didn't seem like they were causing problems. I would like to try to replace my spark pug wires but I don't know how to do that. As always any thoughts or guesses would be great. thanks
