Cb500T wiring help.
Drewce23
Yesterday I was out riding my 76 cb500t around town for a while and I suppose I let it run too long because it overheated some wiring that shut down my fuses. The bike started to sputter and then all of the control lights, blinkers, and horn went out. I got off the bike and noticed the smoke coming out from under the seat. After the smoke cleared I saw where some of the wiring leading to the fuse box was exposed and started to bubble, but nothing was cut or disconnected. I'm just curious if this is no big deal or if it will be a bitch to fix. I just got the bike about a month ago and just got it running again after the starter went out about a week ago. I'm new to working on these bikes so any help would be greatly appreciated. I'll try and get some pictures up soon.
maybe the seat pan somehow pressed on a wire, shorting it? you probably need to check the starter relay system for a dead short too, and if the starter is not working, check the wires to it too. It's worth tracing all the wires you can see with the tank and seat off just for openers looking for soemthing pressing too tight against metal or a craked bare wire. why did the starter go i wonder, and did it take out any other parts like the regulator? you have had a big amperage draw, lucky it didn't smoke the works, and what you are looking for is a dead short to ground. if you can't see it after taking the tanks and seat off and tracing them looking for a bind/bare wire/broken tip then you have to look inside the headlight for a short also. the big amperage thing means wiring bare soemwhere, nothing on the bike draws that much to melt down the wire. maybe the seat has touched soemthing under it?
just trying to help, good luck but don't leave this unattended cause it isn't going away and may smoke the electrial parts.
