CB550/500 Project
riverfever
I have always wanted a project and after helping a friend get a barn find CB650 running, I decided to look for a CB of my own. I don't know much about motorcycles at all but a pinched nerve has caused me to have to give up riding mountain bikes so a motorcycle seemed interesting. After looking at several I found this one in the fall and went and looked at it. It was advertised as a 76 550. I paid $1200 for it. Here it is the day I brought it home.
Although it started, it ran rough and I had to really nurse it along to keep it from stalling. It did not have any sort of filter or air box on it at all. First I wanted to do a thorough tune up on it, get a stock box and see if that helped it run better.
I downloaded a manual for it and started going over all the fasteners. I changed the oil, filter, and the leaking seals under the left motor cover. Then I started cleaning. It was at this time that I realized that the frame was a 76 550 but the motor was a 71 500.
I adjusted the cam chain and valves, and set the points. On a ride up the street, I noticed the front caliper was not retracting so I decided to order a rebuild kit for that, a MC rebuild kit, and stainless lines. The PO had a set of drag bars on the bike but I didn't like them. I had no idea what direction this was going but I always thought Clubman bars looked silly but I kept coming back to them. So I ordered a set and figured this was the perfect time to install them. Now things really took a turn in the cafe racer direction.
Some pics of the front caliper during its rebuild.
Piston was in excellent shape.
While I had the brakes apart, I kept looking at the ugly forks. PO had primed them and they had some deep scratches. So I started sanding them out.
After a 3,000 mile tune up, the bike still ran horribly. The PO said the carbs were in excellent shape but I had my doubts. One night I noticed that I kept fouling out plugs because they were saturated in gas. This had me looking at the carbs more so. I had never seen a carb before and was reluctant to try rebuilding them but decided to jump in and I ordered rebuild kits.
I pulled the bank of carbs off the motor. I was not aware that I didn't need to take them totally apart. In ding so, some things broke.
They were dirty. The jets and emulsifier tubes were totally clogged. I was surprised it even ran at all.
Both of these glorified washers were broken. At this point, I was told that I would need to find new carbs as this part was no longer available. Seemed odd to me. I never bought a bike this old thinking that I would be able to find all the parts needed.
Things were going ok with the carb rebuilding. I used Chem Dip and a lot of elbow grease.
These rubber gaskets all ripped so I made new ones out of an old inner tube.
I made new washers as well.
Nasty.
I reused all of the old brass.
I was bored one night and decided to sand all the ribs and scratches out of the MC cap.
Carbs back together and bench synced.
New fuel line and inline filters.
Things were going well and I started looking at the tank. I have never done body work and I've always wanted to try. I knew knee dents were going to be tough but I wanted them.
I used a combination of a ball peen hammer and rubber hammer ground into a sphere.
I got excited/carried away and was using a small screwdriver to chip away at some filler and put a hole in the tank. Twice.
At this point I felt like a real moron. I decided to take the tank in to get media blasted so I could see how bad things were. The tank was in great shape. Hardly any rust inside and not too many dents. I'm a teacher so I took the tank to school after cleaning it thoroughly and used one of the MIG welders in the metals class to weld up the holes. I also pulled some of the dents from the left side.
I made a bracket to relocate the ignition from on top of the bars to under the top triple tree.
Next up I started working on the body work. This has been much harder than I thought it would be. I have a whole new appreciation for this now.
I finally got to a point where I felt like I was going to have accept the body work imperfections because I am not a professional. I primed the tank and decided to walk away from things for a while. Next I started looking at the rear fender. I decided to bob it 4".
I installed bar end mirrors and a few weeks later, came down with Shingles. One night I was going to work on the bike and went to take it off the center stand and just didn't have the strength to keep it from falling. Broke a mirror. I actually went in the house before trying to pick it up because I was terrified the tank had been dented. Not a scratch. Then I started playing around with relocating the plate. I welded up a simple bracket.
I painted the MC, installed new grips.
I got a new mirror and ordered a new seat cover from David Silver Spares. The only issue with the cover is that loose section (on both sides) where the factory strap was. The foam is broken down a bit in that area but I can live with that.
I went back and welded a tab on the plate bracket to keep it from going into the spokes if it gets loose.
I started looking at the wiring harness and found a lot of areas with suspect splices. I even found some wires that were just cut and left hanging.
I went back in and re-soldered a lot of connections.
This brings us to today. I ordered new gauges from Dime City and went to start installing them.
Much nicer looking.
I re-worked the ignition mount. It flows better with the smaller gauges now.
Here's where I have questions and hope someone can help me out. I have the gauges all wired up. I bundled all the grounds together and wired them up as one (hope this is ok). I attached the neutral positive to the green/red wire off the NSS. I attached the oil positive to the blue/red wire coming off the oil sensor. I left the positive for the blinkers hanging for now as I haven't bought those yet and the PO had none. The positive wire for the hi beam led will eventually go to the new left side control that I also got from DCC. More on this in a minute. The gauges light up and look great but the neutral light does not go on. Not sure why. Any ideas on that one?
Next I installed the left side control and started running those wires. I got the horn wires connected. Again, the turn sig wires will be capped off for now.
This is the wiring diagram for the switch I bought. I don't know where to go with several of these wires.
Can anyone help with the wiring? What do you need to know to make it easier to give help? Thank you.
-Chris
