CB550 Battery Drain
cafe kid
I had trouble starting my bike. My buddy found a bad condenser! However as I suspected from earlier outings
the battery seemed weaker after riding. So when I would come home I'd plug the battery in. What is
causing the drain on the battery? Any ideas? The battery is 6 months old and I had a battery tender on it all
winter. Thanks for your help!!!
Maybe the regulator/rectifier. If the rectifier is faulty, the will drain power when the bike is stored.
Anybody know where I can get one for a decent price? The ones I've found (OEM) are 130 to 150.
I cant spare any more bread! I just put a bunch of money into it recently. Or can I hold off for a few
months and just charge the battery. Or will that cause a downward spiral of electrical part problems
Wreckers or ebay is your best bet. It may be a hassle but you can disconnect your battery when parked in the garage.
Probably a short somewhere, it is a good time to clean all the connections and put die-lectric on them.
Check the battery voltage on the bike, then with the key on, then when starting and finally increase revs to see what the output is. Should be around 14.5v
