FunJimmy
Re: CB550F Interceptor
With the front end and brakes all sorted out, it’s time to finish up mounting the headlight and get started on a fender.
Hey here’s an interesting trick! The Buell M2 headlight mounting brackets were the only 43mm brackets that I could find at the time, but they never really looked right so I found these really cool T-bolt stainless steel clamps and fabed up some custom headlight mounts.
These where so easy to make that you can easily play around with angles and dimensions till you get the right setup for you. The T-bolt clamps also come in many sizes so this should work for any fork diameter.
