CB550 Restoration Project
laran
Active Member
I've been posting so many threads I figured I'd just start one thread for the whole project.
What are some ideas related to wiring during a restoration project? It's a god-aweful mess of wires up around the fuse box. I've seen some chopper builder vids on youtube that mention running wiring through the frame. Does that happen with cafe builds? Seems like overkill.
Really what I'm looking for is just a really clean front-end to the bike. Probably an Acewell gauge, a teardrop headlight and hopefully nothing else. Everything else I'd like to be as hidden as possible.
Any ideas for how to clean everything up?
Turn signal wiring. I'm confused. There are three wires coming out of the turn signal unit, each with male connectors. But there is only one female connector for each turn signal. Where do the other two wires go?
I've read that the red is always positive and black is always ground. And one of the three wires is red, the other is black But I can't think of what I'd ground a turn signal to.
I've attached a pic of the unit.
Thanks.
what you've got there is a running light/ turn signal combo.
Black is ground
black/white = running
red = signal
I believe
On you're wiring harness look for a green wire that has a large female connector. There will be a space for 2 male connectors, you black wires will go there from both lights. This is the ground wire.
Like this
if there is running lights on your bike, you should see a blue wire, a blue/white wire, an orange wire, and an orange/white wire. The wires with the white tracers are your running lights and the blue and orange wires are your signal lights
if i got the red & black/wire mixed up, just reverse them.
Black is ground
red = signal
I believe
Like this
Perfect, the green wires were right there. Hooked them up and all is well. Super! Thanks.
So this is a noob question I'm sure. How do I disconnect the clutch, throttle and choke lines? I've tried fiddling with the end that terminates at the controls. It doesn't want to let go. I can almost see where the ends near the motor terminate. But I'm hesitant to try to disconnect them without understanding how they're connected, etc.
Thanks.
So I'm trying to remove the carbs now. Clymer tells me that I need to unscrew the clips holding on the rubber chamber/tube from the airbox into carbs, unscrew the clips holding the rubber chambers/tubes going from the carb into the cylinder intake and remove the bolts holding those chambers/tubes to the cylinder head. The bolts securing the latter to the cylinder head are easy to get off for the two outer carbs, but for the two inner carbs it's super hard to get an allen wrench in there to loosen them up. I managed to get the top bolts off for the two inner chambers. But I can't get an allen wrench in there for the bottom bolts. The wrench bumps into the bracket to which the four carbs attach.
Has anyone got any special tricks or recommendations for other tools that might be easier to get in there?
You can see the bolt in the attached photo.
I have a feeling that there's more room to work on the SOHC motor than it is on the DOHC motor.
The clips are usually a 'Phillips' screw head.
This is way too big a can of worms for me.
I see unfinished project for sale in a few months.
You have more hope than experience which is usually a recipe for disaster.
I hope you prove me wrong
The usual procedure is to loosen clamps on both sides of the carbs, the slide the airbox back in the frame, and away from the carbs. You may have to undo/shift a few things to give you room to do this, but I'm not familiar with your model. Once the airbox is back, you need to pull the carbs out of the engine-side boots, and slide them sideways out of the frame. As you will see, there is very little room to work here, and it's a fiddly job, even if you'e done it before. You gotta really want those carbs off to attempt this ;)
One they're off, you can get at the boots. But you wouldn't remove them unless you were going to replace them.
Didn't see any photo??
cheers
ian
one tip at getting the airbox out of the way is to put a ratchet strap between around the front of the airbox and to somewhere on the frame then tighten the strap. it will pull the airbox away from the carbs and free your hands up for fighting with it. It's a PITA to get them in and out.
It will be easier to diconnect/reconnect the choke cable once the carbs are out of the way
