CB550 spoke size/ gl1000
wrxdwpsti
Ok, so im doing a cafe build on a 76 cb550. Im a bigger guy and ive decided that those dinky rims need to go! did some searching and found that the gl1000 aluminum rear rim (D.I.D.) that i have can be laced onto the hub of the cb. the only problem is i have no idea what spokes to use.... the rear wheel on the gl is a 17, I believe the cb is the same (although narrower and not as thick) does this mean i can buy the spokes that would usually go with the cb? ANY help would be great, thanks!!!!
-Dennis
These guys are the experts, you'll have more luck there.
http://www.buchananspokes.net/
yeah I talked to Carpy and he said to talk to them... I sent an email to their tech support people.... just waiting for a response
First off the rear on a 550 is 18", so just switching the spokes won't work, not to mention they used different hubs, and drive systems for that matter so the spokes most likely are different lengths. The rear wheel on the Wings were also shouldered, whereas the 550/750s were just a normal style rim.
I did the exact same thing on my cb500 I am using a cb550 rear hub a 17 in cb750a (same part as gl1000) hoop and and reused the cb750a spokes an nipples it worked great I would check spoke part numbers for the gl aginst the cb750a on bike bandit I would be shocked if there different "life is only as hard as you make it you may already have the parts you need avon makes the tire you will need
