CB550 Turn Signal trouble
phrige
I'm a pig, I'm A dog so exuse me if I drool.
Anyone have any advice for my current hang up?
There is full power to the turn signal relay, no matter what I've tried thus far I'm only getting 0.8__volts to the rear turn signals.
Anything I should look for? The bulbs seem good, as do the grounds at the rear signal seem alright.
Front signals do light, in middle switch position they are full glow running lights, to the right The left signal lights up and turn to the left the Right signal glows.
Ive tried to check the grounds, and rechecked all the connections. Short of something being wrong in the handlebar control I'm a little stumped.
Could my turn signal relay just be busted?
Thanks,
Pete
can't be the switch, front work OK.
Check rear grounds and wiring inside headlamp shell (or connectors under front left of tank)
PJ
I've been playin with it since your post PJ,
seemingly just not getting current back to the rear turnsignals. When I plugged it into the brown coming off of the rear stop light, I'm guessing residual charge, it was able to put 5volts true the particular turn signal and no flashing just steady glow.
The connections in the bucket seem in order, everything is plugged in the appropriate place concerning the turn signal set up.
I mean its unlikely that somewhere in the harness there is a break in the wire. still mulling it over in my head.
Working things are front headlight and read brake light.
I have stock 550 left handlebar control that handles tunrsignals.
Right Handlecontrol are from a CB360, and electric start is not hooked up.
Brown is tail light wire.
Orange and light blue are indicators.
Green is ground, goes to Black with green band at indicator
Fuses tight in fuse box?
Stock indicators or aftermarket?
Pull bulbs and check bulb holders, could be corroded/bad connection
Thanks PJ, I'll try it out.
I'm using fuses that are longer than stock but still have a good amount of contact.
I ordered some stock ones that should be in this next week.
I just attached a pic of the fusebox since I had one on hand. and shows the turn signal flasher P.O. rigged.
Found one potential problem, an obvious over sight, I believe there should be a third ground wire coming out of these stock front signals which is absent.
The backwards left actvating right was a miss labeling of the wires. I'm guessing the previous owner somehow added black wires and colored bands on them.
They may have had some tinkering on the internals from the P.O. they are dual filament bulbs on the front, but like I mentioned no ground wire coming out. I'm going to pull them out, where can I solder up a ground wire if its completely gone?
**Edit**
From looking online at stock cb550 front turn signals all that I've seen are two wire jobbies, No ground I believe, while my schematic shows green coming from signals and connecting in headlight bucket. Help? lol.
re-read previous post.
black with green band is stock Honda for indicator grounds.
You have 12V going into relay on black wire,whats coming out and going to switch? (grey wire)
If fronts are working it shouldn't be a problem though (you are looking at indicators and not running lights at front?)
The front are just running lights, I see the black with green band in the rear, they are plugged into the green grounds that run forward I believe.
Here are the pictures of the connection under the seat,
and the front a missing ground maybe causing the lack of power to the rear? I know relay is getting full voltage so there must be a break somewhere futher up.
These are the only two wires coming out of my front signal, is that right? Grounded inside the signal?
That looks about right (could probably do with tightening up abit and cleaning?)
Whats voltage into switch on grey wire?
OK well at least the grounds taken out of the list of possibilities.
The grey wire could be the problem, I only was getting .130 volts when the front signals where glowing. I'm guessing this should be full voltage.
In the schematic whats the block between the Relay and the wire that leads to the headlight bucket? Possibly rip or other malfunction going on in there.
The relay when I just checked it was not reading full power, don't know why It was before . I have black and gray connected. When I check black and ground I get 5.00volt reading.
3 prong relay my answer? and even then that is not full voltage is it?
Measure black when its not connected, then measure grey at relay (or at least the terminal where grey would fit)
Probably a god idea to start doing some resistance checks of wires
PJ
The black unconnected and grey at realy, individual voltage measurement? What do I connect both multimeter prongs to in that case?
For resistance checks both mutlimeter prongs on the same end?
Sorry for the ignorance, trying to learn the proper methods so I get the right readings.
Red meter lead to what your measuring (in Volts)
black to a good ground
In Ohms, check each end of wire,(one lead on each end, does continuity and resistance.
lower is better) touch meter leads together first to check what internal resistance is in meter , may be 0.000 or as high as 0.2 ~ 0.3 ohms.
PJ
I think I got ahead of myself in focusing on the rear signals.
The headlight I realized I had rigged jumping a Black into the Brown and white stripe circuit. Which was feeding power to the headlight and the Front signals.
Everything wire wise in the bucket is wired properly on second idiot check, same in the back.
The last time I took the bike out was at least 9-10months ago. at that point it had a charging problem where it basically didn't charge the battery and turn signals never worked. Since then I got a new rectifier, thinking that was the fix to the charging problem.
is there something that could be a contributing factor to both problems, or at least a clue to a bigger problem somewhere.
So doing a proper check I turned up with proper power getting to the turnsignal relay. I'm not sure what I was doing to get the wrong readings earlier.
Is there supposed to be any continuity in the Turn Signal Relay?
yes there is, - no there isn't,
It's a flasher :D
You may get continuity with meter leads one direction but not the other if there is a diode in there, try switching leads
haha, thats what I figured.
I wasnt getting a reading either way actually, interesting note when i plug into the black and grey for continuity test I get continuity when its in the left turn mode but none in right turn mode.
Theory: this may have something to do with the Brown/White, since its not receiving proper power. Tracing that whole thing now.
Fusebox when i unscrewed it for closer inspection has had a melting over load on the Red main circuit, the bottom fuse holder especially. decent amount of melted plastic. Wires seem black on the back, I'm guessing from heat, and a little frayed at one connection(red) there are 1/4 at least of the strands disconnected.
I'll look into a new fuse box since this one i'm guessing is worn, Though it was still giving decent current through it.
Any opinion on changing it to a blade type fuse box?
Hi, I'm new in this forum, my name is Armando
I do have a similar problem with my CB 550, well my turn lights glow, but stay static, I already check the flasher and it is working okay.
Does anyone knows what's the problem?
Maybe I installed the flasher in a wrong way, because there is 3 wires there and the flasher only accept two, do anyone knows what are the color of wires that should be connected to the flasher?
Thanks
