Did you say that even if you hold the throttle slightly open, it still will not fast idle? What about at 1/4 throttle? It should rev pretty high with no load and 1/4 throttle, so don't do it for more than a second or so.
When you cleaned the carbs/jets did you check that the pilot jet outlets are clear? That's teh tiny drilling through which the air-fuel mix from the pilot jet discharges into the throat of the carb. Typically they are less than 1mm diameter and they tend to clog up with fuel deposits and corrosion.
I always blast carb cleaner through all the drillings and I check one carb against another to see that they are all more or less the same.
