CB550F Clutch set confused on what to buy.
trn714
Hi guys, I'm looking to replace my clutch from my 77cb8550f found this set but confused on the discription. it says
CB550F Super Sport - 1975-1977 - 7 clutch discs needed (6 are the same and 1 is different) so do I have to get another different plate? or everything is there already? ???
http://4into1.com/ebc-clutch-plate-set-ck1146-honda-cb550-cx500-gl500-gl650/
easy deal.
you need p/n CK1146 . . The odd plate with the wider tabs goes on last.
if all your plates are exactly the same which they should NOT be on your year, you need CK1147 and do not use the odd plate.
