CB550SC Rings on a CB550F
sxecafe
You think the Carpet Pissers did this?
I fucked up and bought rings for the '83 CB550... does anyone know what the main difference is? I hear they wont work but what specifically? If its just the oil ring then Im in good shape....
HELP! ??? ??? ??? ??? ??? ???
OUFFF... you don't wanna close the engine to figure out later that the ring dosen't give you enough compression...
But you can always check the manual for the ring gap that they should have, push them alone in the cylinder and take the mesure you'll see if they can fit as for the size... after check with the piston so they fit...
Rings needs to have a clearance of .002 inch INSIDE the piston grouve, so between the ring and the wall of the piston, that's the main problem because if they have not enough clearance, your pistons can jam.
Its up to you but if you want my 2cent... don't mess with piston and rings... ;).
I mess with pistons and rings all the time.
If bore is same size and ring thickness is same, you just slide it into clean unworn part of cylinder and check end gap.
The 83 motor is completely different to 70's motor, 4 valve DOHC compared to 2 valve sohc
This can be done for sure but I would'nt do it... you know why? Because I want rings that are made for my piston/bike. I know usualy these only a few kind of rings but I would want to make a bad mistake. I'm talking about my 500cc pistons kit that cost me an arm... I don't wanna fry them... but if you wanna try it on an old motorcycle and old piston, I mean, its a good way to lurn for sure :).
It's all good dudes... I was able to cancel the transaction and save face. Thanks for all the insight though.
