Personally, I dont like pods.
Id rather run a stock air box and put a custom UNI Filter inside.
The stock airbox guarantees equal airflow into each of the carbs. Pods dont especially on a cb550K where the space between the carb and the box is very tight, unlike on a cb750. On a cb550, carb #1 & #4 will get more air, (since its on the outside), carb #2 & #3 will get less air, since its in the inside.
If you run pods on a cb550, there is a chance (from what I've heard), that you might have to jet the #2 & #3 carb differently to compensate for the lack of air, (depending on the climate of where you live), or at least certainly tune the air/fuel mixture screw differently than carb # 1 & #4.
Also, the jetting depends on the type of exhaust you are running... There are many different variables you'll have to consider.
If this is you first bike, and its running fine, then Id leave it.
If you want more horses, but a bigbore kit, racing cams & Mukuni Carbs....or get an R1
We put in a 595 Yoshimoura big-bore kit on RUDEBOY's 75 cb550K, along with cb750F tank, 4-1 Exhaust, UNI filter in the stock airbox + a bunch of other cool mods and SHIT its FREAKIN FAST!!!... It left my cb550F on the line!!...
