Last weekend I picked up that CB650 SOHC 4 engine from Randy (harper750) for a buddy of mine. It's an 80 or 81 from what I understand. I think he plans to put it in a 4 wheeler or something. Anyways, a free engine doesn't come without a catch. So, in an effort to get this thing run-able for my buddy, I took the head off to see what I got. Well, I'll tell you what I've got. Two stripped head bolt threads (where it threads into the case) and one head bolt that wouldn't come out and rounded. I drilled the head of that bolt to get the head off, as I figured if I can't get that off, this thing's screwed anyway. The spark plug in cylinder 2 is broke off. Not just the porcelain, but between the hex and the threaded part.
I honestly don't know how that happens, but I have the proof downstairs that it does!
So, upon more inspection, everything else seems in great shape. Cylinders are nice, pistons and rings are all pretty decent. Cam chain tensioners aren't worn much at all. Everything looks decent.
So, a list of things I'll be needing to get this hassie put back together and running:
-Top end gaskets - head gasket, cylinder base gasket (any other ones I should have???)
-Second in from the right, front head bolt. I can measure the part that was still in the case, as there are a few different length bolts.
-I have a HeliCoil set that I think might even be the right size for those stripped holes.
-Ratty old exhaust just for getting it running.
If anyone knows any other things specific for these Honda 4's to look for while I have the top end apart, please let me know. I'll be cleaning everything, maybe even lap the valves, who knows.
Lastly, what do you think something like this should be worth to him? Running of course, after I put my time and money into it. He wants to trade a 79 CR250 and an 80's Honda 175 dirtbike. The 250 apparently runs, and both bikes are ROUGH!! Like, spend at least $500 each to get them half decently reliable kind of ROUGH. My MX250 is in better shape. He also wants me to throw in a set of side fairings for his 84 CR250, so that means finding them, and buying them.
Any thoughts, please let me know.
