CB750 Starter Clutch Problems?
Nighthawker
I recently picked up an 82 cb750 DOHC for $100 from a friend. I was having problems with the starter engaging the engine as it would sometimes turn it and sometimes just have a spinning sound similar to a powerdrill. I ordered a new starter, and installed it but had the same symptoms. Took off the side cover to check things out, all the gears are in good condition teeth wise. So I took out the starter clutch to find that its springs were way over compressed and broken in places. My local honda shop had the springs in stock so I replaced them. The results were the difference of day and night, the engine was turning over every time I pressed the start button. But the next day I was back to my old symptoms. I'm baffled. Any ideas?
Thanks in advance,
Grant
i have a link to a whole rebuild kit for it. it's on my other computer. I can get the link for you if you like.
Turns out that the starter clutch bolts came loose after the new springs fixed the original issue. I put some locktite on the them and they're staying now. Thanks anyways though.
It's a problem with 750/900 and Suzuki GS1000.
Sounds like big ends are knocking.
The Honda starter clutch also has issues with rollers Brinnelling center section of big reduction gear
