carvedtangent3
I am planning a cb750 build and i like the looks of the 1978 gas tank. Will it fit on any other frame from 69-78? Thank you
Thank you for your detailed answer. So you mentioned the petcock placement. Would it hit anything or would i just have to run a longer line?Redbird said:Carvedtangent, which '78 tank are you referring to?
The '77-'78 "F" model tanks wont fit anything but a '77-'78 "F" model frame. Not without some frame work anyway. (they're physically longer)
The '77-'78 "K" model tank will cross over much easier, all the mounts are the same. But as chicken mentioned, the fueltap placement is slightly different between the two.
Basically, the later tank is physically wider, and the fueltap reflects that. The early tanks have the fueltap approx. 1" closer to the tank centerline than the later tanks.
Below is a pic of the underside of a '75 K tank (left) and a '78 K tank (right)...
These are both spare tanks for me, and I never tried to actually fit the '75 tank to my '78 K model. And as you can see, there may be some clearance issues on the underside. Especially if fitting an early tank to a later frame. I ran a tape measure from the front mount to the back of the rear mount, and between the front mounts. And both measured up the same, +/- 1/8". If you want/need more specific measurements, just holler![]()
I didn't suspect you were, I just wanted to make sure you knew I wasn't eithercarnivorous chicken said:I'm not getting testy...
