cb750... too much oil
Anybody?
I rode for the first time today after an engine rebuild and a big bore kit... got almost all the way home (40 minute drive) and noticed oil... and quite a bit of it... dripping from the underside of the engine. Got home to check and my mechanic had put about 1.5 litres too much oil in it. I've taken alot out with a turkey baster but it seems to still be dripping. Could this be oil overflow? Will driving it too full of oil cause any damage? I saw a little on the front of the engine also... possibly coming from the exhaust area...
Any insight here is greatly appreciated. I don't want to take the engine apart after having it rebuilt.
Thanks
Eh...Bad news. You may just have to. Only to replace gaskets tho. And maybe seals and piston rings. How far did you go with all that oil in theres?
Rode about 50 minutes. It pees oil when the engine is running... but doesn't leak at all when stopped. I took out the excess oil last night and took it for a spin... still had a bit of leaking when I got home. It's coming from down around where the chain disappears under the engine.
Can somebody give me an idea of what could be damaged by riding with too much oil?
I run an extra quart of oil in my CBR900RR engined car. If I put in too much past that, I get clutch slip. That didn't happen to you? Honda motors are built extremely well. If it were me, I'd drain the oil and put some new stuff back in. Then clean the engine up real well and monitor the oil leakage.
Since it was your first ride after the rebuild, I'm assuming you didn't rev the engine too high. As such, your oil pressure should not have been too much.
I wouldn't worry. I know my CBR900RR motor is newer, but it also runs around the track at 13k rpms for 20 minutes at a time.
--Chris
too much sometimes results in it pouring out the venting. then you take off from a light with the ass end dancing in your own oil slick - or at least that was my experience.
If there were no plumes of oily smoke coming out behind you should be alright. Change the oil and filter and try again with the correct amount of oil.
