CB750 Tsuma
The stems came in today so I was able to make some progress finally. If you ordered one it will ship tomorrow.
All pressed in
Into the neck for a test fit.
I also had these retro nuts made to fit a gsxr stem. I just love the way it all turned out.
http://cognitomoto.com/collections/gsxr-conversion-parts/products/retro-nut-for-gsxr-conversion
vbtravisd said:
Looks sharp man... does that nut work on a factory cb750 stem?
The nut only works on gsxr stems and looks like the original CB750 nut. I think it completes the look well. Here is a before and after
Hey guy I recently became a "site supporter". In honor of this I'm running a DoTheTon exclusive on the Retro Top Triple Clamp that fit stock forks for the CB450, CB500T, CB750K and CB750F.
Check out my post on it
http://www.dotheton.com/forum/index.php?topic=54818
Threw on the wheels from the CB550 for mock up. Then a set of 14.4" shocks.
http://cognitomoto.com/collections/electronics/products/honda-rectifier-1
Little update. Had this electronics pan made. Bolts in where the old battery used to go
www.CognitoMoto.com
This build has been on the back burner for a few weeks now but I've been gathering parts. I'm going to use the harley hub because it's already laced and disc in the rear looks cooler than it is functional. Disc was there so I figured why not. Picked up a rear caliper from a harley off eBay for $65 shipped. The axle hole is 3/4" (19mm) so I'll need to bore it out to 20mm. Little test fit
Looks promising.
www.CognitoMoto.com
Replaced the stock harley bearings with the 20mm ID bearings. So far so good
Diameter difference.
Axle installed.
Now i will bore out the caliper and see what spacers I need.
www.CognitoMoto.com
Got my seat pan and the length I want. This seat length doesn't work with the existing frame setup.
Trying to get it looking correct before anything gets welded.
www.CognitoMoto.com
So I made some pins that match the inside of the tube perfectly to ensure the loop matches the frame.
Cut down the loop to get my length.
Ah...
Seat pan
Removed the tubes and started playing with strut location.
Bored out the rear caliper. Need to get spacers figured out.
www.CognitoMoto.com
