cb750 velocity stack questions
nailbomb
here is a picture of the filters.
Do i need a filter element to put in these? or can i run them just like this? this bike is not my DD, i just want to make a light, loud fast cafe racer.
what do you guys think?
I had velocity stacks on my '75 750 when I got it and it continually fouled plugs until I added some air flow resistance. If you put something in them your bike will run better and clean the air going into the engine.
You cant just stuff those with foam though or the foam will be sucked into the engine instantly so you'll need something to prevent that. What I did was install half the original airbox with the filter inside it.
The best velocity stacks for a cb750 are OEM which are inside the air filter box. They are the right size and shape and the filter is not as restrictive as people think.
I already have the velocity stalks in the picture. I wanted to know what if i should use some kind of filter or element inside of them or what?
Use individual pod filters with properly oiled screens, filter elements and the correct main jets. Velocity stacks are the most efficient means to suck sand, dirt and debris into your motor.
Stacks were designed for track use on race motors which were rebuilt every 24-50 hours of use. They do suck in alot of air along with everything in it. There is a reason nearly every street bike built in the last 70 years or more have filtered air. Velocity stacks may look cool and have a perceived speed increase, they will wear down your motor quickly.
If they are what you want, run them as is... I've never had any issues. Your oil will get dirty a lot faster. Keep it fresh. you'll be fine.
See now I see a few people like Louie tell me its fine, then i see people tell me just "NOT" to do it at all.
the bike is not going to be a daily rider. its going to be out when i go to bike shows or i want the looks. I think i will just do it.
It's all personal preference man... What every one is saying is true. You just need to take all the information and make a now educated decision.
running stacks on my cb550 this year.. an old track racer told me to use panty hoes stretched between the carb and the stacks.. it's not going to keep everything out. but its better than most screens or.. nothing.. and once your wife/girlfriend puts a hole in her hoes.. you got your self free filters... lol
what i am probably going to end up doing is using filters out of industrial coffee machines, trim to fit and zip tie em on.
