I have been doing a lot of work on my recently purchased, previously abused 1981 cb750c and I seem to have made something worse. I have been doing a lot of cleanup of the wiring, oil change, swapped out the pods for the stock air filter and probably a bunch more things I cant think of. Before I started it ran, not well and the battery wouldn’t charge but it ran.
Now when I hit the start button I hear the starter relay click and then nothing happens. When I let go of the button I hear a whirling coming from the starter motor (I believe) for a second or two but the engine does not turn.
I thought maybe the starter motors gear was dislodged from the main crank case gear (I barely know what I’m doing and am pretty much shooting from the hip) so I tried to take the left hand crank case cover off to have a peek. I noticed 2 things.
1. The timing lines (s | f 1-4) do not line up correctly with the indicator point and as hard as I try to turn the hex nut it wont budge counter clock wise like the manual says and I can turn it all the way clockwise but not far enough to line it up.
2. I can’t seem to take off the larger side cover (with the 8 bolts) I take all 8 bolts loose (plus the two that hold the plate on the inside) and the case will budge a little in the top right corner but not on the bottom left corner. Couldn’t get it to move off at all. I must be missing something.
So I guess my question is what am I missing here and does any one have any ideas about my starting issues. I don’t mind getting my hands dirty but I’m a little over my head.
Thanks!
Saben
Thanks!
Saben
