NagChampa
Troddin' through the valley
Picked up a 1973 CB750 for less than scrap prices a little while ago. It had been ridden hard and left for dead in storage, then moved to a backyard where I found it. Definitely will have to put some work into this before it will become road worthy.
This is my first project as well as my first bike. Yes I know that most barnfinds cost over a grand to get started. I am actually more interested in building and learning about this machine than riding it right now. There will be time to ride in the future but will probably have another project by then. Hopefully with help from the fine folks here at DoTheTonforums and the Honda service manual, I will have this kitten purring in time.
There are a few issues that have to be dealt with, my short term goal is to get it running, ride it for a season, take it apart for a shave, paint and polish, put it back together again and enjoy.
As I brought it home. First thing to go would be the sissy bar. Paint will not be so purple in the future as well.
4 in 1 header pipes are crudely cut off just past the collectors. They are also pounded flat on the bottom. Not sure if they are worth saving, probably just keep them for welding practice in the future. Definitely going on the 'Maybe' pile for now.
I had to take a before photo
Few days later
Some of the wiring was held in place with string
This is why I am going with new wiring, that and the liberal use of red automotive wire with hand twisted and electrical taped connectors.
Had to drill off the handle bar switch gear on both sides.
Left over damage from previous side car conversion. Looking at right side passenger peg triangle. I debated restoring this frame to stock specs but will likely cut off these triangles in the future for a cleaner look.
Now this is what you call a booger assed weld job. I don't know what to say but the weld should probably be fused to something
Clip for front fender support is broken. Anybody know if these are still available? Will probably not be putting the fender back on the bike, will go in the 'for sale' pile
Found a spare motor on kijiji, the motor in the bike had a hole in front of the sprocket. Will get this one running in the bike and will have a machine shop weld up the original case. Original motor will be rebuilt or sold/bartered for parts.
Pistons on spare motor look like they should.
Bores look good, will just give a quick hone
Will take these apart and try to get everything blasted clean.
That is all I have for today, have to borrow some tools from my brother to remove valves this week.
*****Now using a 1978 F frame and parts. The 1973 has damaged engine cases, engine will be used for spare parts. The frame is too rough and damaged from what appears to be a botched sidecar installation, the large dent on the down tube just bothers me. Not interested in using JB Weld to fill the dents, instead will be lopping off the neck to use in a future project. The rest of the good parts will be sold to recoup my investment.*****
Few days later
