adam750
I have a '78 CB750F Super Sport, it is in extremely clean condition, no rust, no old cables, etc... and it does not seem to want to start in temps below ~52 degrees. Once it's warm it idles great, and it runs great in all gears. The previous owner put a Dyna system in, and I'm wondering if that may be the cause of the problem. Battery is strong, carbs have been recently cleaned/synced, new spark plugs.
I have to hold down the elec start for a long time (when it's cold) while the engine is trying to start. One trick that seems to help is to adjust the idle speed to much faster than it should be. I do this just when I'm trying to start the bike, I have to slow down the idle speed once it warms up(otherwise it would be idling at ~2500RPMs).
I'm pretty new to maintenance/adjustments... but I was planning on trying to diagnose the problem by taking the carbs apart, checking the timing, float levels, etc.. I was just wondering if anyone has advice in where to start?
Thanks in advance
Thanks in advance
