CB750K in NE Ohio
Scrappyike
Howdy all,
Just got a 74' CB750K which has not been ridden in 10+ yrs judging by the plates. Getting it cleaned up and will attempt a start to see if it runs. Engine does have compression.
Top pic = Bike now
Mid pic = My Goal
Low pic = Paint scheme
I will post progress about mid way into the project. I'm sure I will be posting questions before that. Glad to be here.
Ike
Will do. I've been debating with or without the fairing. I will for sure do without the rear fender. Out of curiosity what design flaws have you noted?
Get rid of that weak single caliper front brake setup. You'll be glad you did. There are literally tons of Honda bikes that have better brake setups that don't require huge modifications. Personally, I swapped the whole front end off of a 82 Nighthawk and got dual discs and anti-dive. Only thing to keep in mind is fork diameter, but you can swap triple trees if necessary, good luck!
That is on my list. Looking for either CB750F or CB900 forks I saw on a previous post.
