CB750K2
VicSkimmr
Well, I might as well make a build thread on my bike now that it's time to start getting to work.
I bought this CB750 K2 off eBay back in October with the intention of making my own CR750 out of it, which is my favorite bike of all time.
The bike is a '72, 5k original miles, all original as far as I can tell. The first thing I did was replace the tires and change the oil, but so far that's it.
CB750 by jasonwithers, on Flickr
Once it got here I realized it was in way better shape than I could have hoped, so I've been spending the past 4 months trying to figure out if I still wanted to do that much work to it or just clean it up and go for a more OEM+ look. In the end the wife said absolutely without question there was only ever going to be one bike, so I decided I'm going to try and do both. I'm going to try and make it so I can fit the CR750 tank and tail while also still being able to use the stock tank and tail if I want to. I have no idea if that's possible or not.
So, first things first, I need to work on the front end. I'm accumulating parts from a '76 GL1000. So far I have the wheel assembly, forks, triple tree and brake calipers, and I got new gauges and an upper triple from DCC for Christmas, so I'm mostly there. I'm just waiting for everything to arrive before I get started. I still need to get clip-ons, the master and brake cylinder, brake lines, speedo cable and a new headlight assembly. But we're getting there.
Re: CB750K2 to CR750 (ish?)
yea.. that's too nice to chop up... please find an old turd to rebuild and customize into your dream CR replica
That way you have saved this nice original bike... and also given a junker a new lease on life :)
There is nothing of worth around me, I live in a motorcycle desert (if you ignore the harleys). After searching for 6 months I realized my only option was to buy on eBay, so I figured if I'm going to be paying to have something shipped to me, I better make sure it's a decent bike.
Like I said, I've been struggling with the decision on whether to cut it or not ever since I got it, but I've made my peace with it. If it was a rarer bike I might have decided differently.
The only thing I plan on cutting is a bit off the rear of the frame, I don't plan on doing any more than I need to. This isn't going to be a straight up replica of a CR750, more of an inspired-by type build.
No matter which way I decided, the rear end would be getting some love anyway. That rear fender and tail light has to go.
what a shame... that is a sweet, original bike :'(
It is way to nice of a bike to hack up. While I do believe it is better to start with a good bike then something they is just a pile of parts that resemble a motorcycle it is hard to see a survivor go. Most of the issue is that rarely is the "built" bike as good as the original, more often then not the newbie just hacks the bike into a none running heap that is only good for taking pictures of with a graffitied wall as a back ground.
Sad to say I already see a few newbie mistakes in your future, way more concerned about the fate of the bike....
One bike can't be all things, so I'll ruin the suspense now.....you can't swap from a CR tank and seat back to a stock set at will when you are finished. Personally if this is your first vintage bike or build I would recommend something a little more subtle. What I would do is service the crap out of the bike you have now and ride the hell out of it for a season. Get to know the bike and figure out the weaknesses and then improve each system of the bike as time goes on.
Few other things to get out of way first, here is a list of instant fails in my book....sure signs of a poor build
-cutting off the rear fender and frame. Zero reason. Also weakens the frame.
-lack of a front fender
-clip ons or clubmans without the proper rearsets
-clubmans on anything larger then a 400cc twin
-lowering the bike
-talking about swapping disc brakes for drums
-hammering knee dents in stock tanks
-pod filters
-replica non dot tires
-junk shocks
Like I said, think about some simple upgrades.
Dual disc is a must, you are looking into the GL swap so you gain an alloy wheel, dual discs, larger front end and a lighter front end. A nice set up would be superbike bars, the clip ons will be way to low with the stock pegs. Tarrazi makes a beautiful set of bolt on rearsets that would work well with clip ons, but still would like to see clip ons that had some rise in them.
Swap an alloy rim onto the back. A hondamatic wheel will bolt on, but is a 17 and subpar, so spend the money and get a custom 18 drilled and installed. Order some Hagon shocks, maybe progressives. Something they is a real shock. Think about ones an inch longer then stock, or stock DOHC length.
Don't relocate the battery or install pods!
There are a ton of other simple mods that will improve the bike and make it more fun, join sohc4 and read up there.
Look, we're not talking about a sandcast bike here, it's a K2 in decent shape. It isn't perfect by a long shot, pictures hide lots of flaws. The previous owner had the case painted because a colony of mice had destroyed the paint. It's not like this is a show quality bike and many things would need to be replaced either way. I'm not about to sell it after I spent so much time researching, scouring the internet and paying to have it shipped to me. Like I said, I had a very difficult time choosing whether to keep it stock (mostly) or do more serious work to it, and I've decided that I'm going to do work.
I've been lurking on this site since 2011, I've read more threads than I could hope to count. I'm also a member of sohc4.net and I've been pouring over that site for nearly as long. I'm not someone who buys a project and tears into it without knowing what they're getting into. The whole point is to improve the bike, not destroy it. I've been riding it constantly since I got it, and now that it's gotten too cold to ride I'm ready to get started. I'm only starting out with a front end upgrade, sounds pretty subtle to me. I haven't laid out a time frame for this build and I don't intend on doing it all at once. Winter only lasts about 2 months in coastal South Carolina.
and I'm frankly not concerned about your list of automatic "fails." Most of them are common sense, and the rest are your personal opinion. The CR750 itself has the rear frame modified, there is plenty of purpose and reason to do it.
I appreciate the help and I know for sure I will need it along the way, but please don't treat me like I'm mentally retarded just because I'm new. You have no idea how I work or what I do. You don't know my history or anything about me other than what I've laid out in this thread, which is almost nothing.
Go for it man, its your bike and you're gonna ride it. I'm rooting for ya
oh, rad dood ,,, chop that bitch up and make it your own!
fuck yeah !
>:( first things first >:( anybody knows the fist step is rip that ickie,nasty waring harness out
Withers said:
...................please don't treat me like I'm mentally retarded just because I'm new. You have no idea how I work or what I do. You don't know my history or anything about me other than what I've laid out in this thread, which is almost nothing.
I agree with you all the way Withers, build it the way you want, and take as long as you need. I hate how there is this attitude that everyone must follow a single narrow minded path when building a bike. You see the same things written over and over again, without regarding your skill level or even enthusiasm level.
The fact that this is a very nice condition bike makes no difference, you paid for it. If anything, it is a win-win situation for the builder and purist alike, especially if that purist is looking for great condition OEM parts that eventually show up on ebay.
Subscribed, really want to see a restoration or your take on a CR750 styled bike evolve.
My old lady said the same thing and now there's five. Guess what, she's not going anywhere and neither are they.
Yeah but I'll let her think that way for now. Later comes more bikes.
Actually my original decision had been to keep this bike stock and get a RD400 to convert to a vintage racer. If I can eventually slip one of those into the garage in time I still plan to go that route ;) But like I said, the chances of finding anything decent here is almost nothing. I have to be realistic.
The tank and seat would be the very last things to change, so there's still plenty of time for me to change my mind. First up is the front end, then rear sets and cleaning up the stock lines a bit.
There is a right way and a wrong way.
Before trying to "build outside of the box" it is important to know how to build a dam good box.
How excited you are to do something counts very little. Basic skills are important as are silliness to learn and the ability to do so.
Number one trait of a builder that will produce a quality product is knowing when they are in over their heads....
To many gung oh guys take a bike and turn it into a pile of stuff listed on CL, what's the fun in that?
As stated I/we have no idea of the skills of the OP, it's the Internet.....
Don't focus in the web, find locals and focus there. Assuming that most of the struggle to find a bike was due to only using the web as a tool to find one.
Like was said, it's a honda so it's not rare.
Nice clean survivors are harder to find and more people want them so it's a same if it gets lost.
But what I was saying is it is one thing to take a clean bike and make it into something better then it was stock. I'm 100% down for that and hope that is the case here. But what I am fully against is some newbie that doesn't know the working end of a screwdriver hacking into a bike thinking he can mimic what ever junk was posted on pipeburn and is now his desktop background....
As a disclaimer I have no idea where the OP falls. It's the web and I don't know him.
Maybe the OP can tell us a little about himself, his skills, experience and goals.
-lowering the bike
-pod filters
-junk shocks
Pardon my ignorance, but why are clubmans unacceptable on anything larger then a 400cc twin? Also, what is the issue with a set of high quality pod filters paired with a properly jetted carb?
What's wrong with chopping the rear frame as long as it's replaced with a loop and/or adequate bracing?
I'm not trying to be sarcastic or anything, just genuinely curious haha
Clubmans are small bars for small bikes.
When installed on a large bike they normally need to be angled oddly and therefore not good.
With quality pods and tons of jet work one can limit most of the power losses, but to what end? Most guys buy the cheap pods, and the ones that don't then cheap out thinking they only need to buy one set of brass. For the most part the money spent on pods, either running well or poorly could be better spent on other mods. Pod thing became more dress up then anything else. All of the pod filter issues are MUCH worse on CV carbs.
What good does a frame loop do?
Again, mostly a dress up thing.
Guys often cut the rear bridge of a CB in order to better fit a seat. Some install a loop to clean up the look. Most do not install a brace to strengthen the frame between the shock mounts.
Just a rear loop is not enough.
So you are telling us that enthusiasm does not matter but your little list of newby mistakes does? Enthusiasm is probably the most important thing to have when starting any creative project and not a single build is completed without plenty of it. Almost anyone can gain the skills to cut, weld, wrench etc.
Not too sure what you mean by right or wrong way to build a box but statements like that are largely subjective and obvious to everyone here. No need to imply that anyone is attempting to build a box the wrong way, not sure what gave you that impression as the OP has not actually started his project.
So what if there are guys who are in over their head, too Gung Ho and turn it into a pile of stuff listed on craigslist? Does that affect you personally in any way? And what do you mean where is the fun in that? Isn't wrenching in the garage the fun part?
Again, it does not matter how clean his bike is before he works on it because it is HIS bike. If I had a choice, I would rather start with a showroom clean example than a craigslist find but that is not possible for everyone and what do you mean better than stock? When you say 'better' than stock, it really has no meaning, the word better means different things to different people, and they are all right to a degree.
If a newbie does not know the working end of a screwdriver tries to mimic something from pipeburn, more power to him for having the enthusiasm to learn how to wrench.
Thanks for the info. You speak of "dress up things" as if they are a bad thing. I know I, as well as many others here, prefer excellent function paired with good form. A functional bike with no form is nice, but add some "dress up things", to use your words, and it becomes even nicer. When the mods discussed above are executed properly, there are no issues that constitute an "instant fail". Just my two cents.
Anyways, don't want to hijack OPs thread. I say go for it with the build if that's what you really want to do. It's a nice original, but there's always more. Plus it sounds like you have a pretty clear vision of what you want to accomplish so I'm sure you'll get there.
