wab
Hi guys, so I have been putting my bike back together and have hit a snag! On the cbx carbs the choke is cable operated. The cable attaches to a arm which should lift four in number plunger type things? Sorry for my ignorance but carbs are not my area of expertise.
Anyway, when I operate the choke lever it is quite stiff and not a lot happens at the carb end. I don't want to be too heavy handed as the arm does'nt look that strong.
The carbs where sat on the bike for quite a while in my friends garage, they have been through an ultrasonic cleaner also.
Is there a way to free them up without removing the carbs again? as the airbox set up was a pig to put together and I don't want to do it again soon if I can help it. Also how much movement should I see at the carb side?
Thanks in advance for any help.
Here is the link to my build on here.
http://www.dotheton.com/forum/index.php?topic=29931.msg321820#msg321820
